Scale timeline 問題
Scale timeline 問題
文章siub » 12日 11月 2007年, 09:15
如果可想將成個animation (i.e. 所有objects) 既某段timeline scale快或慢,正確做法應該點做.
另外如果我淨系想將某個object既某段timeline scale快或慢,又應該點做呢?
唔該大家先!!
最後由 siub 於 12日 11月 2007年, 11:00 編輯,總共編輯了 1 次。
siub
文章: 40
註冊時間: 15日 10月 2007年, 12:14
文章sobig » 12日 11月 2007年, 10:24
right click the object u want to edit.
choose curve editor,
on the top main menu, choose Scale Keys (a icon) for X axis (speed)
select the keys you want to speed up or slow down.
for Y axis (value),
choose Scale Value, then, scale it.
hope this help
文章siub » 12日 11月 2007年, 11:07
thanks. If i have many objects in the scene, that means i have to select all the object at once and do the scaling, right?
siub
文章: 40
文章LoGao » 12日 11月 2007年, 11:10
or
1. right click on the time line -> configure -> turn on the Show Selection Range
2. select your object with keyframes
3. select the keyframe, you may see the keyframes turn white in colour and there'll be a Selection Range bar under the keyframes
4. feel free to scale your animation with the start point and the end point
o}-<
LoGao
文章: 523
註冊時間: 5日 5月 2004年, 01:51
文章stantang » 12日 11月 2007年, 14:38
sobig 寫:right click the object u want to edit.
for Y axis (value),
hope this help
Maybe I'm old fashioned, I believe the safer way is scale the keys in dope sheet mode instead of curve editor so there won't be any chance to screw up the value of the keys. You can use either Edit Ranges (whole animation) or Scale Time (your choice of timeframe) to retime your keys.
文章siub » 12日 11月 2007年, 14:59
Thanks all!!! I will have a try at home for various methods mentioned.
BTW, if i want to achieve a smooth "slow motion" effect for a specific time range in my animation without changing the overall frame rate, can I achieve that by all of the above methods?
Thank you.
siub
文章: 40
文章siub » 12日 11月 2007年, 20:32
I've done. Thanks all for the help.
siub
文章: 40
文章sobig » 15日 11月 2007年, 21:32
stantang 寫:
for Y axis (value),
hope this help
thx, stantang,
yours can be a better way to do... :)
