一個簡單的立體繪畫插件
版主: ed209
一個簡單的立體繪畫插件
文章moc » 24日 10月 2004年, 15:01
首先大家別期望太高...
因為它只處於0.1.3版本...
連v1.0都未到大概只是beta左右....
不過非常流暢....速度十分好....
工具迉面比較少選擇.....
不過操作非常直覺...
LMB Drag = Paint
RMB Drag = Erase
CTRL+RMB =alpha channel eraser
Shift+LMB = Draws a straight Line with each LMB click
CTRL+Shift+RMB = Draws a straight Line with each RMB click in alpha.
ALT+LMB/RMB = Orbit/Spin
ALT+SHIFT+LMB = Pan
ALT+SHIFT+RMB = Zoom
大致是塗鴉作用.....
不過如過只用處對位後在PS加工...
作用還是不錯...
咁就唔使勞煩到DP...BP....
最緊要是它是免費....
newtek的論壇上都有講呢個...
http://vbulletin.newtek.com/showthread.php?t=29576
插件上這裡找...
http://cgi.f23.aaacafe.ne.jp/~fisjunk/plugin/plugin.php
moc
文章: 735
註冊時間: 21日 8月 2001年, 08:00
文章moc » 26日 10月 2004年, 18:43
發圖發檔案
要就自己拿....
唔錯...
它的功能解釋...
It is super abridged edition plug in of the generally known 3D paint.
It corresponds to only ULTRAVIOLET RADIATION mapping.
Note 1: It cannot handle the sub patch directly. After freezing (triangle) doing polygon formation
type at number of partitions at the time in rendering, please apply.
Note 2: The picture which it retains unless image is renewed by hand, is not reflected on the
modeller.
Note 3: There are times when file classification does not agree to original type. (Presence of
especially alpha) please pay attention.
Note 4: The maximum picture size which it can handle is to 2048x2048. When it is larger than that,
reducing below maximum size, it compiles.
Note 5: Unless it is display environment above the 24bit color, it does not operate.
* Basic mouse operation
LMB Drag: The line is pulled.
CTRL+LMB Drag: The line where the contour becomes blurred is pulled.
RMB Drag: It is the eraser.
CTRL+RMB Drag: It is the alpha channel eraser.
These can do rectilinear drawing with SHIFT combined use click.
ALT+CTRL+SHIFT LMB: The texture color is picked.
* Buffer operation key
Image a time retention/it returns.
Eraser function has returned the image of the temporary retention buffer partly.
C: Image is retained in the temporary retention buffer.
X: Image it returns from the temporary retention buffer.
Z: Undo (only one time validity)
* Picture indication operation
ALT+LMB/RMB: Object revolution
ALT+SHIFT+LMB: Object movement
ALT+SHIFT+RMB: Zoom
moc
文章: 735
文章moc » 26日 10月 2004年, 18:48
支援繪圖板....
無問題....
FIsUVChalk-i-0_1_3.rar
(19.39 KiB) 被下載 441 次
moc
文章: 735
文章moc » 26日 10月 2004年, 18:51
貼埋圖上來....
moc
文章: 735
文章moc » 26日 10月 2004年, 19:12
記著啦....
每畫完一部份...
記得按一下"C"記憶下....
否則一按"Z"即undo就會全部無曬.....
mouse RMB是擦膠.....
都埋佢仲未支援32bit即唔可以有alpha channel....否則無顯示唔到個模型....
moc
文章: 735
回到 NewTek LightWave 3D
