cad tools for LW
版主: ed209
cad tools for LW
文章moc » 25日 1月 2005年, 01:16
確實十分有用的工具...
部份其實曾出現在免費的插件堆中....
但這個非常全面的.....
也能看到新V8 sdk的開放度....
操作好自主及直觀化....減少了介面數值的操作....
好有型格....
希望下版LW可以吸納這個.....
http://www.wtools3d.com/index.php?menu= ... rana=curve
This documentation is the very concise description of the LWCAD package. The routine LightWave knowledge is necessary.
A few notes about the LWCAD before you start:
Every tool in this package works with the snap to point ability. Every tool handle works in ORTHO mode with pressed <ctrl> key. All geometry created and modified is based on the LightWave curves. Every tool works only in primary layer. Some tools contain a special tool buttons usable directly in viewport. Line segments and joined curves uses double points in curves.
Some LightWave tools are not familiar with double points therefore please use only curve to poly tool for convert curves to polygons!
LightWave curves are not very precise. For low curvature curve segments the error is negligible, in high curvature curves the error is significant. Use refine curve tool to lower high curvature objects!
Check your content directory in General Options panel. The content path must be real. Otherwise the Shape Library will be functionless. Use automatic installer for installing LWCAD.
Read the Install Notes file first.
Snap Modify Usage:
This subset of snap modify tools works with all types of geometry elements used in modeler. Not only curves.
Move snap tool :
The tool has two modes:
Move mode - move object with the left mouse button or numeric panel
Drag mode - drag object point with the right mouse button
Numeric Panel parameters:
Pivot position - adjustable position of the object pivot point
Pivot - adjustable index of the object point. Adjustable also with mouse in viewport.
The tool works in 2D and 3D viewports.
Note:
The snap to point ability in 3D is bordered with the circle region. If you move handle outside of this region there is necessary one more mouse click to recount snap region around last mouse click. This disadvantage is caused by limited possibility of the lwsdk . But it works. Just one more click is necessary.
Rotate snap tool :
Regular rotation - rotates object with the left mouse button or numeric panel
Mirrored rotation - rotates and mirror object with the left mouse button or numeric panel
Mirror - ON/OFF check button for mirror mode choice
Angle - adjustable parameter of the rotation
Tool buttons:
M - ON/OFF check button for mirror mode choice
The tool works in 2D viewports only.
Scale snap tool :
The tool has three modes:
Scale 1d - stretch object along the line
Scale 2d - stretch object in plane
Scale 3d - stretch object in 3d space
Scale Type - tool mode choice button
Factor - adjustable parameter of the stretch
Tool buttons:
1D,2D,3D - ON/OFF check button for fast mode choice
Curve Primitives Usage:
All tools in this category create 2D curve based primitives. The tools work in 2D viewports only.
Line/Spline tool :
The two tools, one for create line and polyline and second for create spline primitive. Both have a variable count of handles.
Pivot - adjustable index of the tool pivot. Adjustable also with double mouse click
Closed Line/Spline - checkbox for closing line/spline. Opening must be processed by the mouse in viewport.
Delete last - button to cancel last added point
Arc tool :
Arc tool creates the arc sections. It has the four handles.
Point 1 - adjustable position of the arc start point.
Point 2 - adjustable position of the arc end point.
Point 3 - adjustable position of the arc mid point
Center - adjustable position of the arc center point
Radius - adjustable variable of the arc radius
Control points per turn - normalized count of the curve control points used to create arc
Circle tool :
Circle tool creates the circle object. It has the three handles and adjustable pivot handle.
Center - adjustable position of the circle center point
Radius - adjustable variable of the circle radius
Control points per turn - normalized count of the curve control points used to create circle
Ellipse tool :
Ellipse tool creates the ellipse object. It has the five handles and adjustable pivot handle.
Center - adjustable position of the ellipse center point
Width - adjustable variable of the ellipse width
Height - adjustable variable of the ellipse height
Control points per turn - normalized count of the curve control points used to create ellipse
Rectangle tool :
Rectangle tool creates the ortho rectangle object. It has the eight handles and adjustable pivot handle.
Center - adjustable position of the rectangle center point
Width - adjustable variable of the rectangle width
Height - adjustable variable of the rectangle height
Rec3p tool :
Rec3p tool creates the free rotated rectangle object. It has the three handles.
Rec3p modes:
Rectangle mode - create regular rectangle
Extend mode - create rectangle with missing base side
Start point - adjustable position of the base side start point
End point - adjustable position of the base side end point
Extend mode - ON/OFF check button for extend mode choice
Length - adjustable parameter of the rectangle length
Tool buttons:
E - ON/OFF check button for extend mode choice
Edit Curves Usage:
Join/Explode Curve commands:
This two commands are able to join and explode back connected curves. In the connection points are used double points to achieve the equal shape of curves than before operation.
Merge Curve command:
Merge Curve removes redundant curves.
Connect Curves command:
Connect Curves command makes connection between ends of two open curves. Intersections are not taken in account. Very usable command after offset tool operation.
Curve Knife tool:
Curve Knife tool provides a curve intersection operations. It has the two visible handles and next one invisible center handle.
Wide mode - knife line is doubled with adjustable distance
Slice mode - every curve cut point is connected with other cut points along the knife line in order
Cut mode - works only in wide mode and remove every curve rest between knifes
Start point - adjustable position of the knife start point
End point - adjustable position of the knife end point
Slice - ON/OFF check button for slice mode choice
Cut - ON/OFF check button for cut mode choice
Knife Width- adjustable parameter of the knife width
Tool buttons:
W - ON/OFF check button for wide mode choice
S - ON/OFF check button for slice mode choice
C - ON/OFF check button for cut mode choice
Curve Offset tool:
Offset tool works with complicated curve scenes with many curves in one use. The tool recognizes the one outline loop and the rest inline loops if there are any. The best way how to understand how this tool work is try it.
Single side mode - offset outline or inline loop curves into the side which depend on the sign of offset parameter
Double side mode - offset every curve in both sides and remove original
Offset type - tool mode choice button
Offset - adjustable parameter for the offset distance
Curve Round tool:
Regular round mode - provides the smooth round of every corner of adjacent line segments in every curve.
Sharp mode - emulates chamfer tool. Original chamfer tool will be in next version.
Round - adjustable variable of the round parameter
Control points per turn - normalized count of the curve control points used to create round sections
The tool works in all viewports.
Convert Curves Usage:
Curve to Poly tool:
Curve to Poly tool simply converts all shapes defined with curves into the polygons. The tool is resistant to maximum permitted polygon point count. It automatically divide the big polygon into the smaller. The conversion algorithm recognizes a two levels of holes and islands in shapes. The intersection of the curves can cause a wrong result.
Surface - popup with surface choice
Polygon detail - choice button for predefined polygon detail level
Polygon edge curvature - adjustable user defined polygon detail level parameter
Remove curves - ON/OFF check button for remove curves choice
Flip polygons - ON/OFF check button for polygons orientation choice
Poly to Curve command:
Poly to Curve converts every polygon into the line curve. Redundant curves are deleted.
Refine Curve tool:
Refine Curve tool adds a new points to curve and hold the position of old points.
Automatic refine mode - refines curve in smart way.
Uniform refine mode - refines curve by uniform dividing of segments.
Refine type - tool mode choice button
Divisions per segment - adjustable parameter of segment division count for uniform mode
Curve detail - choice button for predefined curve detail level
Segments curvature - adjustable user defined curve detail level parameter
Reduce Curve tool:
Reduce Curve tool removes non significant control points from curve. The tool holds only position of double points.
Shape Library Usage:
Shape library is divided into the categories:
1d lib - shapes defined by one single open curve
2d lib - shapes defined by one single closed curve
Pattern 1d tool:
This tool is similar to Rec3p tool except the shape of primitive is adjustable. It has three handles.
Start point - adjustable position of the shape start point
End point - adjustable position of the shape end point
Pattern width - adjustable parameter of the tool width
Count - adjustable parameter of the shape repetition
Tool buttons:
H - ON/OFF check button for horizontal flip of the shape
V - ON/OFF check button for vertical flip of the shape
L - shape library choice adjustable by left-right moving mouse
P - shape preset choice adjustable by left-right moving mouse
Pattern 2d tool:
This tool is similar to Ellipse tool except the shape of primitive is adjustable. It has a 5 handles and adjustable pivot handle.
Center - adjustable position of the tool center point
Width - adjustable variable of the shape bounding box width
Height - adjustable variable of the shape bounding box height
Tool buttons:
add to 1d-2d lib tools:
This two tools are able to add 1d and 2d shapes into the Shape Library. The shapes are stored and managed by internal LightWave preset system. Please use maximum 20-25 shapes per library.
LWCAD Options:
LWCAD Options panel obtain basic global options parameters, help and activation. It is recommended to keep default options in this panel!
Web-Based Help - button to open current help page
Activate LWCAD - button to start activation process. Read install notes for more information.
Snap to points
Low Detail Curvature
Medium Detail Curvature
High Detail Curvature
Round threshold
Max. Knife Curvature
Max. Refine Curvature
Default Settings - button to set original default settings
Copyright (c) 2003-2005 | W -Tools | All rights reserved.
Contact: support@wtools3d.com
moc
文章: 735
註冊時間: 21日 8月 2001年, 08:00
文章moc » 25日 1月 2005年, 01:18
還有Example
Example 1
Build your house for five minutes!
Example 2
Shape Library in practice.
Example 3
How easy could be created a freeform way.
moc
文章: 735
回到 NewTek LightWave 3D
