LW 8.21更新檔
版主: ed209
LW 8.21更新檔
文章moc » 5日 3月 2005年, 00:27
下載啦....
原廠的...
www.newtek-europe.com/uk/support/downlo ... Update.zip
好似話唔使crack架.....
老D都啱喎~~~~~~~
好似大部份都是bugs fix....
而且是骨部份的...
Summary of Addressed Issues (8.2.1):
Affected Area: Summary:
Layout Bone Fuse will no longer cause a crash if each
bone has a child bone
Layout Bone Split will handle multiple children
properly now
Layout $INVALID MESSAGE ID messages in various menus
should be fixed
Layout Bone Split will now break bones properly with
Spline Interpolation
Layout VIPER should no longer crash after working on
gradients in the VLight panel then rendering
Layout Highlight Viewport Selection in Scene Editor
should now select collapsed children
Layout Global Light Intensity and Global Flare Intensity
have been reset to exceed 100% and -100%
Layout Mirror Hierarchy will now mirror goals correctly
Layout Joint Move tool will not cause tip of parented
bone of edited joint to pop away
Layout Bone Twist will not cause bones to pop away
Layout Bone Connect will now snap child bone to parent
tip if parent already has child bone connected
Layout Copy Hierarchy will put the copied hierarchy next
to the original
Layout Import RIG will now import nulls correctly
Layout Bone Split will now spit correctly
Layout Bone Fuse should now work correctly
Other Deleting a bone in the middle of a hierarchy
will not shift out of position
Other RLA image saver now save/load images correctly
Other Importing a RIG will now load correctly
moc
文章: 735
註冊時間: 21日 8月 2001年, 08:00
回到 NewTek LightWave 3D
