ELSA Fire GL? T2-128
http://www.elsa.com.tw/EN/Products/deta ... newsid=256
有冇人可分享經驗???
Graphics processor : ATI FGL? 9600, Core Clock:400 MHz
Memory : 128 MB 128-bit DDR SDRAM, Memory Clock: 600 MHz
BIOS : Support of VESA BIOS 3.0
Bus system : AGP 4X/8X
2D/3D Features : Full 128-bit floating-point precision frame buffer, 8 parallel rendering pipelines, 4 parallel geometry engines, High-level shader language (Fully programmable VPU with OpenGL® API and Microsoft® DirectX® 9.0 class), Full support the latest OpenGL® API and Microsoft® DirectX® 9.0, Microsoft® DirectX® 9.0 functionality in OpenGL®, SMARTSHADERTM 2.0, SMOOTHVISIONTM 2.1, HYPER ZTM III etc.
Extended motion compensation for full screen video playback in all HDTV and DVD resolutions, video acceleration for MPEG-1, MPEG-2 and INDEO. OpenGL Overlay support.
Graphics Standards : OpenGL® API and Microsoft® DirectX® 9.0
Standards : VESA DPMS, DDC2B, plug&play
Connections : DVI-I / D-Sub
Dimensions : 172 x 108 mm (ATX format, not including the mounting bracket)
Operating systems : Windows® XP, Windows® 2000, Linux®
Package Contents : Extensive printed manual in English, Drivers and tools on CD, 1 x DVI-I to VGA adapter.
Quadro4 900 XGL
http://www.kingfung.com.hk/hkhtml/p_q4900x.htm
Quadro4 900 XGL 產品特性
硬體疊覆平面
硬體防鋸齒線條
雙面投影
全景防鋸齒
第二代閉塞選擇
第二代光速記憶體架構
單一顯示器支援 2048x1536
第二代nfiniteFX引擎
硬體支援Microsoft® DirectX® 8 和 OpenGL® 1.3
Quadro4 900 XGL 產品規格
NVIDIA Quadro4 900 XGL 工作站繪圖晶片
第二代可程式化nfiniteFX? II 引擎
128MB 128-bit DDR 記憶體
nView 多重顯示技術
雙頂點著色引擎 - 第二代可程式化特效處理器
雙 RAMDAC,350 MHz,每熒幕可顯示 2048 x 1536,75 Hz
Flexible multi-screen solution with full 3D support
支援兩個DVI-I熒幕
NVIDIA先進的桌面管理系統
支援nVIDIA 整合型架構驅動程式 (UDA)
預設晶片跟記憶體時脈為 300/660MHz
記憶體頻寬高達 10.4GB/sec
60 million triangles/sec
1.2 billion pixel/sec
ProCDRS-03 up to 103 fps
MedMACD-01 up to 96 fps
