Neighborhood
Neighborhood
文章BennyCG » 13日 11月 2002年, 07:34
Hi everyone. I'm a new member in this forum. I have recently graduated from my school and now I'm currently looking for work.
I just wanna post a pic I did earlier using SOFT XSI. What u think?
最後由 BennyCG 於 13日 11月 2002年, 07:40 編輯,總共編輯了 2 次。
BennyCG
文章: 6
註冊時間: 13日 11月 2002年, 07:26
Re: Neighborhood
文章BennyCG » 13日 11月 2002年, 07:38
any comments or suggestions?
BennyCG
文章: 6
A beginner's Comment : A little dark in this scence.
文章Willow » 13日 11月 2002年, 09:16
HI,
I'm just a beginnner. But a simple comment, I thinks this scene is a little bit dark, especially the building's front. Also, if possible, add some hi light on some object (since all details you have build fine but flat in look because the lighting) Hope can hlep you.
Willow
:oops: :oops: :oops: :oops: :oops: :oops:
Willow
文章: 76
註冊時間: 2日 10月 2002年, 17:31
文章antony lau » 13日 11月 2002年, 12:51
O~
this CG is very good~ i very like it~
the texture and modering is very good job~
不過如果個“簷”可以做好d就好啦!
ZENDA dESIGN
antony lau
註冊時間: 24日 4月 2002年, 00:06
文章Iori Keith » 14日 11月 2002年, 04:09
看圖令我想起DC游戲 - 莎木.
Texture做得非常好.
Iori Keith
文章: 118
註冊時間: 21日 12月 2001年, 08:00
文章HapZungLam » 26日 11月 2002年, 22:26
As many people said, the textures are greatly done. However, you may want to spend more time on lighting. Good lighting will bring your textures one step further
I hope you've been read the 5 tutorials of Leigh from cgtalk. Try to add diffuse map and spec map as a combination to the textures that you have. Specially diffuse map. I didn't know anything about it b4. once i try to use it. i love it.
