recent works for hobby^^
文章rryria » 1日 8月 2003年, 01:58
Thanks for comment!!!
rryria
文章: 504
註冊時間: 1日 10月 2001年, 08:00
文章Dick Ma » 1日 8月 2003年, 03:13
Good, you know Rhino and LW... :oops:
Dick Ma
文章: 347
註冊時間: 19日 4月 2002年, 23:46
文章zaptos » 1日 8月 2003年, 11:35
rryria,
Your identity was disclosed....FBI is watching your activities.(Whispering)
Is there a good way to export Rhino NURBS surfaces to LW polygons in 4 points rather than 3 points?
zaptos
文章: 46
註冊時間: 8日 6月 2002年, 23:54
文章chatho » 1日 8月 2003年, 17:35
牛棚? :lol:
有做過資料搜集wo...
點解唔做埋十三街ar...好正ga唐樓... :wink:
texture可以detail o的,加油~ :wink:
Live For Create.
chatho
文章: 309
註冊時間: 19日 5月 2003年, 22:47
來自: 鏡像世界
文章pirotase » 2日 8月 2003年, 01:19
我好鍾意個筆刨 ~
Nice work ~~~
pirotase
文章: 382
註冊時間: 4日 11月 2001年, 08:00
文章rryria » 2日 8月 2003年, 01:58
hi all friends,
thks for u guys comments!
i know that i still have a lot to improve
sometimes just couldnt help posting the works :oops:
dick ma,
yes ar, i learn rhino recently, it's quite easy to learn
it's suitable for u too!
zaptos,
what u mean by "whispering..."?
i think it's impossible to export rhino model to mesh in 4 point polygon because there's some mathmatics inside... of course i dont know la... even for maya or max...
but for still image, i think it's quite affordable in lightwave
i am eager to use lw8 because it supports unlimited points and polygon in one object, this greatly reduces the trouble conversions between lw and rhino...
p.s. the triangle mesh is the most reliable method to keep the appearance as nurbs form so far... we can apply "smooth" for the triangle mesh in some cases... of course not perfect all the time
chatho,
yes ar, because i had a school project working for there before
it takes me a lot of time...
pls forgive my lazy texturing... it really takes time to do in details
pirotase,
thanks for your support
it's surely not my design, it comes along with me over 20 years
:P i will keep rendering some pictures if i have time
rryria
文章: 504
文章tdk » 2日 8月 2003年, 02:02
rryria 寫:hi all friends,
from version 6, lightwave already removed the limited of points and polygon in one objects.
it's a problem with the rhino exporter, may be it's still using lw 5 objects format to exporter.
tdk
文章: 373
註冊時間: 16日 11月 2001年, 08:00
文章rryria » 2日 8月 2003年, 02:19
hi tdk,
yes, thanks for your remind
i just check from my manual... it really support!
then, the problem surely comes from the older exporter
because i still use rhino2.0
i dont know what updated in rhino3.0
:oops:
rryria
文章: 504
文章antony lau » 2日 8月 2003年, 13:42
O~ :D
i like the 筆刨, the design is Q~
ZENDA dESIGN
antony lau
註冊時間: 24日 4月 2002年, 00:06
文章Siegfried » 4日 8月 2003年, 18:02
Rhino 3.0 improved in the modelling method, almost nothing got improved in exporting........did you try .stl format?
