ask question about some functions
文章rryria » 12日 5月 2002年, 23:02
1/ how can i do box modelling with symmetrically select and move? i.e. let's say i move pt A from +x towards 0,
then pt B from -x towards 0.
2/ how can i change my xyz handler to be "move in one axis handler"? i hope u guys can un my question...
rryria
文章: 504
註冊時間: 1日 10月 2001年, 08:00
文章Iori Keith » 15日 5月 2002年, 14:49
you means to array the box symmetrically? or something another means?
when you select the object, you can see the xyz handler turn yellow, when you move the mouse to x axis only, then y axis will be change to green, and click it once times. now you can move it only x axis.
Iori Keith
文章: 118
註冊時間: 21日 12月 2001年, 08:00
文章xam » 30日 8月 2002年, 16:14
select the A and B vetices together, use non-unform scale instead of select and move, A and B will then move in the opposite direction and symmetrically.
