這個燈光效果如何做?
版主: HapZungLam
這個燈光效果如何做?
文章鳥平 » 25日 6月 2003年, 17:06
在XSI裡如何做這個效果?天花的燈光
鳥平
文章: 57
註冊時間: 13日 3月 2003年, 10:43
來自: GZ China
文章HapZungLam » 26日 6月 2003年, 00:19
do you mean glow? like neon glow kinda?
文章h2o » 26日 6月 2003年, 00:40
may be object light.......
文章HapZungLam » 26日 6月 2003年, 01:22
object light? what's that :?:
something he is showing can be easily done with textures. You notice that all the neon lights are constant. So that you just have to make your object constant and paint a weight map to adjust the falloff and the transparentcy of it.
Or, if you want it to really glow. you may select your object and go "get->properties->glow" But the glow is another operation that goes ontop of everything after you render your scene. I haven't tried it on 3.0 or 3.5, but in the 2 series.. the glow operation sucks!!!
文章鳥平 » 26日 6月 2003年, 13:03
用glow的話也有問題,隱藏在物體裡面的是無法glow的。用貼圖是可以實現漸變的效果,但是燈光照亮的效果就不是很好了 :cry:
鳥平
文章: 57
來自: GZ China
文章HapZungLam » 27日 6月 2003年, 10:02
I agree that glow is a very stupid effect.... on most of the 3D application.
But i've created something like that 1 year ago. Where i use constant as meterail add blur to it. Then i use FG as render. It does take a little longer to render. But the roof does reflect the light of it.
Anyhow, i've posted your request on xsibase. Hopefully those professional will come up with a perfect solution.
文章魚魚 » 27日 6月 2003年, 12:25
試試用 3.5 FG Render...
感覺超快速
魚魚
文章: 202
註冊時間: 24日 5月 2002年, 13:02
文章鳥平 » 27日 6月 2003年, 13:12
HapZungLam 寫:I agree that glow is a very stupid effect.... on most of the 3D application.
謝謝你了 :wink:
鳥平
文章: 57
來自: GZ China
文章Zism » 26日 10月 2004年, 22:32
i jst wonder why don't you post a effect sample pic that you wanna to create and we can knw what you want attually. You should knw that is many way to create a same effect...so maybe some1 can help u here.
And...XSIBASE was a strong forum to all xsi user, try to attend there must... u will earn a lot i promise. =)
One "Wu" can't rulez them all ...Onli two "Wu" .....Zzzz
Zism
文章: 12
註冊時間: 26日 10月 2004年, 14:15
來自: Malaysia
文章xiaoxsi » 2日 2月 2005年, 09:18
不是加一個發光效果就行了麼?
插在鍵盤上的紅牡丹還在盛開--肖鏨澤西
xiaoxsi
文章: 19
註冊時間: 1日 2月 2005年, 21:31
來自: 重慶__東莞
回到 Autodesk Softimage
