點解同一個scene用唔同機run會唔同?
文章shape » 29日 4月 2005年, 14:09
做呢頁既野
http://www.mtmckinley.net/tut12.html
向學校做個陣條水柱出得好行既,同tutorial一樣
但我將個scene用我屋企部機出,d水頭幾十frame都冇乜問題(fig. water2),
但之後就塌左落黎,好似腎虧一樣,點解會咁既?(fig. water1)
同埋唔知點解跟佢做都做唔到tutorial fig.14咁散既效果(fig. waterfig14),
我向學校做都系好似fig. water2咁.
同埋想問下等到d水落黎就出水蒸氣要點樣做?除左set個emitter向某個frame出之外.同埋水蒸氣點整架?
water1
water2
waterfig14
shape
文章: 163
註冊時間: 12日 1月 2005年, 15:05
文章tokutoshi » 5日 5月 2005年, 20:53
the first thing it came to my mind maybe it's because the difference of the preference setting in your computer and school's computer. when playing with dynamic simulations in Maya, make sure the frame rate is 'play every frame' rather than 24fps or PALor NTSC etc... because the calculation of dynamic engine in Maya is based on the result of the last frame of the animation (if you dun understand, read the Maya manual). if the simulation is running other than 'play every frame' the simulation may not be calculated accurately. also make sure those other settings of dynamic module in your computer and school's computer are the same to get the same result.
tokutoshi
文章: 14
註冊時間: 16日 11月 2002年, 23:20
來自: New Zealand
文章shape » 25日 5月 2005年, 14:39
ok啦,thank you very much!
shape
文章: 163
正在瀏覽這個版面的使用者:沒有註冊會員 和 10 位訪客
