最近的習作simple object
最近的習作simple object
文章rryria » 26日 6月 2002年, 03:39
by lightwave, pls give me comment!
rryria
文章: 504
註冊時間: 1日 10月 2001年, 08:00
Little comment
文章Siegfried » 26日 6月 2002年, 23:43
1.Try not to bump the indentation only, you can model the concave surface of each patch, it will be better! And the reflection is too much and should be blurred with fall-off and noise bump.
2.B&O Headphone, I have it too and I found your model too thin in diameter, where is the mesh of the speaker and the logo? But the rubber loop is wonderful!
3.Hands of the spectacle is probably too sharp at edges. You can try adding caustic effect! The shadow can be blurred around the farther edges!
文章rryria » 27日 6月 2002年, 03:03
Siegfried,
thanks a lot for your comment!!
haha, u are right, i am lazy to make more accurate.
for the football, i just follow a tutorial on web
it's actually for 3Dmax user.
i just found from lightwave's tuto page.
there is a new tuto for making football.
it's exactly what i need to improve as u talking about as well.
maybe next time, i would use lightwave method to make.
p.s. lightwave method: the bump area is also modeled
by using "smooth shift" --- a wonderful convention!!!
rryria
文章: 504
文章marcus » 27日 6月 2002年, 10:39
er...其實你有冇發覺對耳塞右邊耳反轉左,你戴到左耳戴唔落右耳嫁……
marcus
文章: 54
註冊時間: 14日 6月 2002年, 14:17
文章rryria » 27日 6月 2002年, 16:13
yes u are right...
it's my fault!
rryria
文章: 504
