searchListConnectAttr.mel
文章3don » 31日 12月 2006年, 10:41
simple connection editor.
aim for "search attr name" and "sort attr name" function
for sometime you just not sure the attr name, you can type it to search.
and
for someone really hate to find the attr in connection editor which without a sort attr name
http://www.highend3d.com/maya/downloads ... /4455.html
3don
文章: 18
註冊時間: 23日 9月 2001年, 08:00
來自: Hongkong
new beta version update
文章3don » 7日 1月 2007年, 20:39
Hi all,
I've update a beta version, would like you to test it first.. please drop me comment and feedback here..
updated:
- now is still using "attributeInfo", if it still encounter error in future I would change to use "listAttr"
cause listAttr give me a attr's name too long, which will break the UI.
- add attribute filter to filter the list
- add mutli attribute,
- add nodeType and count attrs info
- connect button moved to buttom.
going to update:
- will add "+ " sign in the list, to indicate it is a multi attr.
- the "connect" button will label the "connectAttr AA.ty BB.tx" directly.
- try to deal with show connected attrs.
I've changed the name from "searchListConnectAttr" to "connectionEditorPlus"....
easy connect.....any node..
easy life..
http://3donwong.sinaman.com/cgtalk/conn ... orPlus.mel
3don
文章: 18
來自: Hongkong
文章3don » 15日 1月 2007年, 02:21
v1.21 2007-01-13
- add ? to show help of the nodeType
- use "listAtr" instead of "attributeInfo" to get the attr list
- add "+ " to multi attr
- bug fix about error when deal with "instObjGroups" attrs etc..
This version is usable now,
Pls let me know, if there is a attr it didn't show, and bug report.
Thanks...
3don
文章: 18
來自: Hongkong
文章ed209 » 15日 1月 2007年, 02:54
thanks for sharing :wink:
ed209
文章: 478
註冊時間: 10日 4月 2006年, 01:05
來自: OCP
文章3don » 23日 1月 2007年, 01:49
version updated.....
// v1.22 2007-01-22
// - add display attr type, so that you can guess can it be connect or not.
// - it can't connect to compund attr before, now fixed, but user need to input index. (like "plusMinusAverage" node)
// - add show hypergraph and select nodes, click "input and output connection" in hypergraph to see the connections.
3don
文章: 18
來自: Hongkong
正在瀏覽這個版面的使用者:沒有註冊會員 和 7 位訪客
