Looking jobs for 3D modeler (part-time/ freelance)
歡迎各[ CG人 ] 在此求職 或 [ Freelancer ] 求 JOBs
請先閱讀"使用守則 "
文章zoeys » 18日 7月 2016年, 23:56
I am a senior Visual Effects student;
and looking for a part-time/ freelance jobs for 3D modeler.
Below is a link about my portfolio:
https://zoechan.myportfolio.com/
May you visit and looking forward to hearing from you.
Zoe.
zoeys
註冊時間: 18日 7月 2016年, 23:49
外號: zoeys
Re: Looking jobs for 3D modeler (part-time/ freelance)
文章ayakiryu » 19日 7月 2016年, 11:22
Hi
Just honestly share my comment on your work ;
I m pretty sure that with the quality of your work will not be help you to get hired . It bases on what I observed :
1. Your website didn't convince your future employer that you have skill for visual effect and most of your works seems more focus on fine art and storyboard telling .
2. As for your modelling skill , you should spend time on understanding the forms and the base principle of modeling includes how the wire frame works . I feel that SCAD didn't teach you quite well for modeling .
3. If you insist to enter in the industry , I must have say build up your foundation skill set at first . For your case do a lot of life drawings and modeling ; do pick a software that you are comfortable with , most of the case you will have if you hired will be modeling and compositing .
4. Join the VFX industry in HK may not help you to improve and they usually dont accept graduate student. Most of them are taking the outsources job , which means they expects employees to have professional skills to finish the job asap .
5. I suggest you to go to a facebook group call ten thousands hours whereas you will given more advice for enter into the VFX industry .
Otherwise you could pm me in cg visual for more advice
ayakiryu
文章: 138
註冊時間: 17日 1月 2010年, 12:48
文章moc » 20日 7月 2016年, 02:45
係咪讀SCAD呢類貴族設計學院,先決係學費吧?
然後如果係俾得出呢個價錢的學費,家境不會差,既然不會差,
畢業就業也就睇"興趣"了!
覺得就業沒趣?就再去外國相關學院再進修咯,相信不是問題.一路Keep著讀,
就永遠無就業問題,反正屋企不等你養,你搵一萬,屋企可以支持你每月駛三萬.
追求夢想也可以好寫意的....一定係.除非唔係.
假如我以上所講,並不是樓主的背景寫照,或樓主一腔熱誠,挨生挨死都想衝入行業.
對於一個畢業生來講,最殘酷就係話佢知,佢落手能力未達標.
樓主好大可能係入設計學院前都未修過美術吧?所以睇到基礎非常不好,很生手.
要做modeling,會較有的困難百倍.需要投入十倍計及更多的製作時間.
所以眼前能做的,一係用常人十倍專注,死磨死綀惡補基礎,仲要堅持以年計學習時間.
否則就轉行去做其他崗位吧.
最後由 moc 於 20日 7月 2016年, 03:37 編輯,總共編輯了 2 次。
moc
文章: 735
註冊時間: 21日 8月 2001年, 08:00
文章moc » 20日 7月 2016年, 02:49
不過又廢話多一句,
其實行業中有好一部份人都係無基礎,只係每次揚長避短.
總之捒自己長處去發展就好快可走得更遠.
moc
文章: 735
文章ayakiryu » 20日 7月 2016年, 08:52
其實一個人功力好唔好都要好睇教佢的人。Scad hk 本身佢地方向係學術方面多個美術。題外話我曾經都揾過佢地想game art.經驗我一定有。但是因為我有喺佢地讀左master,但沒有BFA.
其實件事想講係scad hk 間接害死呢幫學生。
另外樓主有一d現實問題你一定要知,就係vfx 係香港係最辛苦一行,辛苦係接的outsourcing係佔你的人生大半時間。再講既使你係okay都唔好指望人地教你。
老實講如果有心做就啲起心乾去做,如果n吾係就去找其他工
ayakiryu
文章: 138
文章bluelife » 21日 7月 2016年, 11:13
如果你想搵part-time/ freelance做3D modeler
就唔好以為係3D software build到件物件就以為build model好易.
build到件物件只係證明你識用呢個function.
3d model 外型相似係基本, 做唔到呢樣野, 講咩都無用.
學院係其次,n年前無得讀添. 自身努力先係根本. 自己都唔多d接觸,理解,練習..無得攪,做邊一行都係死.
bluelife
文章: 1
註冊時間: 21日 7月 2016年, 10:40
回到 CG Artists Looking 4 Jobs
