唔好意思~~~我有另一難題~~
音樂同動作鏡頭配合~~
例如~我我要分好多個sence做ge~但系我只音樂有成3分鍾
但系我又要跟音樂做動作~~~
祇該點做呢~~~
請c兄教路><
stantang 寫:It's hard to give you suggestion without knowing what are you trying to do, but the normal workflow is to create an animatic 1st, sort out the length of your shots with the animatic, then do the shot one at a time in Maya. You could import a wav file of your music into Maya to help with the timing of your animation.
As for MR and maya software render, there's things that you could only do with MR like GI/FG and you could use lens shader for thing like the fisheye render without model the actual fisheye object. And for advanced users, MR has its shading language so you can write your own shader.
jacky1987hk 寫:C兄可唔可以比d意見~點學先最快最好~~
同埋香港maya課程好似無咁仔~.~
