mental ray同mayasoft問題
文章jacky1987hk » 4日 1月 2009年, 17:43
唔好意思~~~我有另一難題~~
音樂同動作鏡頭配合~~
例如~我我要分好多個sence做ge~但系我只音樂有成3分鍾
但系我又要跟音樂做動作~~~
祇該點做呢~~~
請c兄教路><
jacky1987hk
文章: 142
註冊時間: 3日 1月 2009年, 19:15
文章stantang » 4日 1月 2009年, 22:15
It's hard to give you suggestion without knowing what are you trying to do, but the normal workflow is to create an animatic 1st, sort out the length of your shots with the animatic, then do the shot one at a time in Maya. You could import a wav file of your music into Maya to help with the timing of your animation.
As for MR and maya software render, there's things that you could only do with MR like GI/FG and you could use lens shader for thing like the fisheye render without model the actual fisheye object. And for advanced users, MR has its shading language so you can write your own shader.
文章jacky1987hk » 4日 1月 2009年, 23:17
stantang 寫:It's hard to give you suggestion without knowing what are you trying to do, but the normal workflow is to create an animatic 1st, sort out the length of your shots with the animatic, then do the shot one at a time in Maya. You could import a wav file of your music into Maya to help with the timing of your animation.
唔該曬c兄~~明白~~~
我再試下做先~.~
有唔明再請教c兄你~
希望你唔炎我太煩啦><
thx a lot~~~
jacky1987hk
文章: 142
文章h2o » 5日 1月 2009年, 00:23
我又多口問句... 你系邊度學 maya 架?
文章jacky1987hk » 5日 1月 2009年, 01:15
h2o 寫:我又多口問句... 你系邊度學 maya 架?
我自學的~用開3d max~~
但覺得maya個介面同功能做動畫好d~
所以學maya~~~
jacky1987hk
文章: 142
文章jacky1987hk » 5日 1月 2009年, 01:18
我都想跟人學~~但系出面d課程都好似唔系好得~.~
又貴~~~所以先自學><
C兄可唔可以比d意見~點學先最快最好~~
同埋香港maya課程好似無咁仔~.~
jacky1987hk
文章: 142
文章jacky1987hk » 5日 1月 2009年, 02:56
仲有樣野~我念極都念唔明點做~~
變型金剛~由車變做機械人果part系點做~.~
變左做機械人仲可以當model咁move~
我真系好想知點做~.~
國產的變型金剛~火星臬堂的學生做的(不知真定假)
http://v.youku.com/v_show/id_XMzIwMTYyNTI=.html
jacky1987hk
文章: 142
文章stantang » 5日 1月 2009年, 08:24
jacky1987hk 寫:C兄可唔可以比d意見~點學先最快最好~~
同埋香港maya課程好似無咁仔~.~
If you're 自學, the best thing is to get the "Learning Autodesk Maya" series book and follow the tutorials. When you get comfortable with Maya, start testing out interest by doing some tutorials from site like learning Maya.com.
http://www.learning-maya.com/23-0-model ... rials.html
It's very hard and almost impossible to master every area (modeling, animating, effects...), so you can do some small tutorials in different area and once you found out your interest, you may want to set out a little project in that area for yourself and work as hard as you can to finish it.
It's a journey, good luck!
文章jacky1987hk » 5日 1月 2009年, 21:38
THX A LOT ~I WILL TRY MY BEST~~~
jacky1987hk
文章: 142
上一頁
正在瀏覽這個版面的使用者:沒有註冊會員 和 22 位訪客
