請問點整一個河流???
請問點整一個河流???
文章eidosyam » 8日 7月 2005年, 23:20
請問點整一個河流???
eidosyam
文章: 43
註冊時間: 4日 12月 2004年, 00:55
文章stantang » 8日 7月 2005年, 23:47
This is a difficult question... It can be very simple (model river then keyfram texture) to very difficult (particle, realflow, glu3d...) how realist do you want?
文章stantang » 9日 7月 2005年, 01:02
Found this old gnomon tutorial, http://www.gnomononline.com/movies_free ... _full.html
Try it and see if this is working for you. You can try with the ocean texture if you want a better water look.
文章eidosyam » 9日 7月 2005年, 02:09
i want to realist..
i saw it ... this is very good .
but i cannot follow this steps. can you teach me???
thank you
because he use expression .. how to make water texture??
do he use ocean texture???
thank you~~
eidosyam
文章: 43
文章HapZungLam » 9日 7月 2005年, 04:10
You can just simply model a plain surface, and use a fractal (noise) shader to interact the bump and displacement to the surface.
文章stantang » 9日 7月 2005年, 05:43
eidosyam 寫:i want to realist..
thank you
thank you~~
He didn't use the ocean texture because it doesn't exist when he's making the tutorial (around 2001...)
Why can't you follow the tutorial? Which part of it you don't understand?
文章eidosyam » 9日 7月 2005年, 14:46
how to do dynamics ??
i know that he use soft bodies...
texture problem, he use ramp texture and bump texture..
he use expression, what is the expression??
thank you for reply~~~ :oops:
eidosyam
文章: 43
文章eidosyam » 9日 7月 2005年, 15:10
i want to ask, the bump is 2d texture or 3d texture???
bump value or bump depth???
thank you for reply
eidosyam
文章: 43
文章stantang » 10日 7月 2005年, 23:35
ediosyam, I didn't watch the whole video, so I don't know what expression he used... the bump map doesn't need to be 3d texture, it could be whatever the water texture you will use. as for the bump value, you have to try it youself, it's not that differicult, right?
"how to do dynamics?"
are you asking how he did the softbody? just pick the surface and select create softbody..., then apply some force to it, that's it...... if you're asking for particle dynamics, Maya help has just the information you needed. Search "flow" in maya help. there're two kinds of flow, curve flow and surface flow. Here is a link to curve flow in case you can't find it. http://caad.arch.ethz.ch/info/maya/manu ... 2.fm2.html
文章eidosyam » 11日 7月 2005年, 01:19
thank you for idea..
i will try it...
eidosyam
文章: 43
文章eidosyam » 11日 7月 2005年, 01:26
i saw that he use many texture and utilites..
but i dont know , which type do he use ???
stantang , can you teach me??
because i really want to learn it ..
thank thank
eidosyam
文章: 43
文章stantang » 11日 7月 2005年, 03:52
eidosyam, have you tried to follow the tutorial? Let's forget about the many textures and utilites he used, do you understand what he's trying to do? The basic idea is to offset a texture in U or V on a NURBS surface. all the softbody/utilites are just there to create a better look.
Can I teach you? I'm afraid I'm not qualify for that... there's so many talented, experienced artists here. I think what you have to learn is the problem solving skill, that's one very important skill when you work with CG. Ask the right question is another key skill. Don't stop trying... you'll learn alot through the problem solving process.
I'll try to watch the gnomon video when I have time, hopefully I can mark down what he used in the tutorial...
文章eidosyam » 11日 7月 2005年, 04:24
thank you..i understand..
i will try it...
eidosyam
文章: 43
正在瀏覽這個版面的使用者:沒有註冊會員 和 12 位訪客
