為何不見了移動箭咀 , Help ..
為何不見了移動箭咀 , Help ..
文章tvcat » 1日 11月 2005年, 12:20
為何不見了移動箭咀 , help me please ...
select and move is not work , is not hide it
最後由 tvcat 於 11日 11月 2005年, 19:08 編輯,總共編輯了 1 次。
To be CG, To be love in CG
Tom as a TvCat
tvcat
文章: 17
註冊時間: 14日 10月 2004年, 22:34
文章xam » 4日 11月 2005年, 10:09
take a look at the 3ds max tutorial "Lighting and Global Illumination" is a good start.
But if you don't want to read too much at this moment, at least learn how to use Spot Light, and set up a 3-point lighting sence for self-training is also good. Set up a Key Light near the position and direction of the camera, then set up another in the around 90 degree to the key light and we can call it fill light. reduce the amount of light intensity of this fill light (reduce the multiplier value). lastly, set up another light in the other around 90 degree direction, and call it Rim or Back Light. The intensity is up to u.
Play around shadows (on and off are ok in this moment), the color of the lights..... the density of the shadows.....
remember, once u create a light, render to see the effect and do the fine tuning. after u feel satisfied and then make another. Do put many lights at the same time (you will be lost).
文章alanzam » 28日 12月 2005年, 17:28
i'am afraid that you make a little mistake of hot key, choose a model and set it as move, then press the "x" on the keyboard,
just my suggestion.
A NICE GUY
alanzam
文章: 4
註冊時間: 28日 12月 2005年, 16:46
來自: WUHAN
文章xam » 11日 1月 2006年, 09:11
Thanks....
If you still cannot see the transform gizmo after pressing X, try checking the View menu > Show Transform Gizmo.
文章tvcat » 11日 1月 2006年, 10:51
i got it ... thanks
Tom as a TvCat
tvcat
文章: 17
正在瀏覽這個版面的使用者:沒有註冊會員 和 24 位訪客
