升級3DS MAX 4.2問題 , 急救!
文章Son » 9日 4月 2002年, 14:08
我的系統是WINDOWS XP.
我在升級3DS MAX 4.2 時,在安裝解壓過程中出現
標題為Can't run 16-bit Windows program
內容為The path C:DOCUME~1MY USER NAMELOCALS~1TempWZS12D.tmpsetup.exe is invalid.
的信息,按ok後就裝不了,請救救我...
Son
註冊時間: 9日 4月 2002年, 08:00
來自: Macau
文章Siegfried » 11日 4月 2002年, 00:26
I guess XP wasn't a good environment for 'any' CG software. NT and 2000 Pro could be better!
用4.2版
文章大劍師 » 23日 5月 2002年, 14:53
XP上用3D studio max系無問題,不過我裝時系用4.2版而唔系upgrade,重有系裝完之後入licensing時會有一個小問題,因為果個licensing program系XP到系run唔到,你要download個新版先得.之後就用得好順o勒.試試啦!
大劍師
文章: 35
註冊時間: 1日 11月 2001年, 08:00
文章Siegfried » 24日 5月 2002年, 19:40
Where to download the 4.2.6 upgrade patch?
What did it improve?
And the Max very often quit to desktop suddenly, I believe I have enough Ram(1G) and HD Swap space, and 'just-OK' display card (3D labs VX-1), dual P3 450 CPU, 450W transformer, and SCSI HD..etc. What went wrong with the sudden jumping?
RE:4.2.6
文章大劍師 » 25日 5月 2002年, 00:37
The 4.2.6 patch you can download on 3D Studio Max official web site. The improvement info. you can found in the web site. Just I can remember is that improve performance on Intel CPU.
For you problem that I never encounter. So, I can't help you at this case. But I suggest you doing Windows update to make sure this is not windows issue. Display driver is also a potential problem. You may check and update if necessary.
大劍師
文章: 35
Suggestion
文章Siegfried » 27日 5月 2002年, 01:26
I got my Max from WanChai with $40, you know.....so I think I can't download the upgrade patch from official hompage.
I update my display driver frequently, so that's O.K.
But can you tell me more about the Window 2000 Pro update and where to get it, of course in underground site :P
RE:suggestion
文章大劍師 » 27日 5月 2002年, 10:38
All I said about the patch and update is `FREE`. Just download by yourself.
大劍師
文章: 35
