fake HDRI
fake HDRI
文章h2o » 9日 3月 2003年, 01:47
http://www.cgvisual.com/4images/details.php?image_id=51
我終於post 作品上來了........ :oops:
文章BMBM » 9日 3月 2003年, 15:30
Lovely!! :o :o
........I've no word to say. Just "lovely"!!
BMBM
文章: 86
註冊時間: 17日 7月 2002年, 18:25
Gorgeous!!!
文章ernestkulu » 9日 3月 2003年, 22:42
Wei! Long time no see!
Your masterpieces are very great and cute!!!!
I like their ears are in different size!!!!!!!!!
Add oil ar!
ernestkulu
註冊時間: 9日 3月 2003年, 22:38
非常之真實
文章leeho » 9日 3月 2003年, 23:57
可否給予一些制圖資料 , 比方說 : 多少支燈 , 用什麼來制作模組 , 如何運用物料 , 有此效果 . 因此圖來的物件做得非常之真實 , 可否賜教一二呢 ?
@v@ :mrgreen: :oops: :mrgreen: :oops: :mrgreen: :oops:
文章Siegfried » 10日 3月 2003年, 08:38
Reflection for the black & white bear were probably too much, but the HDRi scene is really marvellous!
Are you using downloaded HDR file?
文章rryria » 10日 3月 2003年, 10:41
Siegfried 寫:Reflection for the black & white bear were probably too much, but the HDRi scene is really marvellous!
h2o said "fake"
so, i think this is not really a HDRI render
otherwise, seems to be a fake by a module of light set
any wrong?pls clarify a bit :)
rryria
文章: 504
註冊時間: 1日 10月 2001年, 08:00
文章Siegfried » 10日 3月 2003年, 11:48
How to fake?
文章rryria » 10日 3月 2003年, 11:54
http://flay.com/LinksByCategory.cfm?CategoryID=8
there are some tutorials to discuss how to fake
but i am afraid i have some misunderstanding between fake GI and fake HDRI
hope u all can clarify it a bit to me
rryria
文章: 504
文章h2o » 10日 3月 2003年, 12:39
After Effects is a key in this fake HDRI. It's not necessary to plug a complicated shader in 3D software.
All the methods are cheats & tricks. Hollywood used this method ten years ago (remember there have no HDR at that time) ........ :P
I know it is hard to change the tranditional 3D concept in HK..... but I did it!
文章Siegfried » 10日 3月 2003年, 13:03
H20
Could you tell us your work flow in AE and lighting setup in MAYA?
文章h2o » 10日 3月 2003年, 22:16
... 我再說多一點.... 不過同時希望大家也想一下怎樣做吧! :mrgreen:
基本上 layers 分了: reflection, colour (bears), shadow, bg
:!: 右邊那只bear 就是只有reflection 的 layer
1. 在after effects 裡reflection 要用 "add", shadow 用"multiply"
2. 跟著用 level/curve 控制這兩個layers, 可以調教顏色及光暗對比 (這個要自己試才會明白這個道理)
3. 調整過後......再加 outfocus 的效果
p.s. reflection 的圖我在網上download 的, 還有lighting 方面...... shadow 這麼soft.....當然用了global light :lol: , 不過colour 那個layer 用數支燈已經可以了 :wink:
文章Siegfried » 11日 3月 2003年, 00:43
How do you make 'outfocus' in AE or Photoshop?
文章h2o » 11日 3月 2003年, 00:59
outfocus 用了tinderbox2 (after effects) 的 lens blur, kpt 都有一個camera blur, 也可以做到 blur 後有一點點的光點 :wink:
.......很多人會 render depth layer 來做 outfocus, 不過after effect 做得不夠好, 所以我勾mask blur了後面那只bear....... 哈哈哈 :mrgreen:
文章Siegfried » 11日 3月 2003年, 08:54
One stupid question, what is the max resolution that AE can output?
The Kpt version?
And where to get tinderbox2?
Thx
文章taognaeco » 11日 3月 2003年, 15:56
勁呀!偉大的After Effect!!!!!同After Effect plugin!!!!!
taognaeco
文章: 26
註冊時間: 3日 1月 2003年, 20:35
