About reversing the character animation . . .
文章liu_0083 » 26日 3月 2003年, 21:38
I want to make a bip file for the motion reversed for my character.
I've tried the reverse time function in the track view. But it seems no action after I've pressed the button. I have already selected the time. Have I did anything wrong ? Or is there any way to do that ?
Thx in advance.
Do what you are to do, go where you are to go.
liu_0083
文章: 33
註冊時間: 15日 7月 2002年, 21:16
來自: hk
Cool
文章xam » 3日 4月 2003年, 23:17
Are u using footstep animation? If not, remember to use the select time button to select the time range you need to reverse (in Dope Sheet Editor if using max5), then press reverse time button.
