請問冰,水,玻璃的材質點整呀??
請問冰,水,玻璃的材質點整呀??
文章小貧窮 » 27日 8月 2003年, 17:34
請問冰,水,玻璃的材質點整呀??
thank you^^
小貧窮
文章: 23
註冊時間: 27日 8月 2003年, 01:27
文章choppy » 28日 8月 2003年, 10:13
你是用什麼軟件???
主要都是控制折射同opacity.
永遠的巨石3D動畫制作團隊
文章小貧窮 » 29日 8月 2003年, 01:59
我用3ds max5的
小貧窮
文章: 23
文章Siegfried » 1日 9月 2003年, 09:24
If U have plenty of time then use Raytrace, if not, simply use refract/reflect.
Re: 請問冰,水,玻璃的材質點整呀??
文章xam » 12日 9月 2003年, 00:11
小貧窮 寫:請問冰,水,玻璃的材質點整呀??
thank you^^
most of the time, the material depends on the geometry. i.e. different shapes will have (a little) different material settings. e.g. a thin glass material will be different with a glass sphere..... i think that's one of the reasons why there is no (or little) material library outside......
Some tips here:
1. Ice: (assume ice cube for cold drinks) a box/chamfer box with enough segments, apply noise modifier. Use Raytrace as reflection and refraction, and alter the Falloff settings of the Raytrace map.
2. Water: (assume water in a glass) Raytrace Refraction.
3. Glass: similar to water.
