Maya 立體動畫創作 ---- 硬件要求
文章feverheat » 23日 3月 2002年, 13:54
各位,我想問下你地用緊系乜野機啊? Display Card 要 support OpenGL 邊一只又會比較好呢,如果display card 方面 Budget 只有 3000-4000 又有D乜野 選擇呢? 我就睇中左 3D labs GVX1 pro 你地話好唔好。我系一個初學者,rendering 時間令到我學習速度好慢啊! 尤其是學習 Fur , paint effect 既時候。 好想你地提供寶貴(專業)意見!
feverheat
文章: 132
註冊時間: 23日 3月 2002年, 08:00
文章stantang » 24日 3月 2002年, 06:05
If you want to render faster, you should ivest more in the CPU (or CPUs). Athlon is a very good choice for that. For display card, even a Geforce3 is fine for normal usage 'cause it won't speed up the render.
文章feverheat » 24日 3月 2002年, 12:11
明白,唔該曬你啊! 咁我就想問下,我見好多人都話做3d 要用雙CPU,但我眼見好似好少雙CPU既Motherbroad 喎,你地而自己屋企用緊系D乜野configuration 既電腦啊!! 價錢又系幾多呢? 如果我要買,Max 都系10000多少小咋....Thanks :smile:
feverheat
文章: 132
文章Siegfried » 12日 4月 2002年, 00:50
2 CPU is slightly better, there are few mother board for 2 CPU, try add more RAM, at least 1G(I have 256Mx3 only) . GVX1 Pro is good as it has output, I used Oxygen GVX1 and VX1 b4, very stable and reliable as it support OpenGL. Elsa is also a very good choice. No matter how good and powerful the config is, try lowering the mesh quantity in your scene is not a bad move!
文章feverheat » 14日 4月 2002年, 02:09
你而家用緊系...... thanks :)
因為display card都幾貴啊!!所以想問多D先買,2 CPUs rendering 系咪會快D架? thanks:)
feverheat
文章: 132
CPU
文章Siegfried » 14日 4月 2002年, 02:57
Dual CPU perform faster, but probably not more than you think, benefit for dual CPU is stability.
My config now(bought in 2 yrs ago):Dual CPU board(made in Tai Wan, model no. forgotton), 2 x P3 450M Hz CPU, 3 x 256M RAM, oxygen VX-1, Ultra wide SCSI HD, Win 2000(WinNT previously)...etc.
By the way, I don't know much about hardware, anybody can tell me about SCSI nowadays?
Try buying more ram b'cas its cheaper than b4, you also needed to spend more $ on display card for faster real-time modelling and rendering.
CPU
文章Siegfried » 14日 4月 2002年, 02:58
Try buying more ram b'cas its cheaper than b4, you also needed to spend more $ on display card for faster real-time modelling and rendering. :wink:
CPU
文章feverheat » 14日 4月 2002年, 13:53
Thanks ~~~
feverheat
文章: 132
Display Card
文章Truth » 18日 4月 2002年, 11:25
如果你對Display card有一定的要求,而Budget 又有限,
你可以嘗試用SoftQuadro改卡,效果理想而且又十分容易。
用較低的價錢便能嘗試到高階Diplay Card 的效果。 :D
以下是對應表供你參考
GF256 ——> QUADRO
GF2MX/MX400 ——> QUADRO 2 MXR/EX
GF2 GTS/GTSPRO/ULTRA /GF2 TI ——> QUADRO 2 PRO
GF3/GF3 TI200/TI500 ——> DCC
Truth
文章: 47
註冊時間: 31日 12月 2001年, 08:00
來自: H.K.
文章feverheat » 18日 4月 2002年, 22:19
我又想問下,其實改左之後貴咭咪要行埋一邊?
feverheat
文章: 132
文章ChildPark » 3日 6月 2002年, 17:31
上298頂樓有套裝機買,本地同行都有很多人找他買機,砌機都可以,自已買可能撞板,初學者最好用單CPU底板,因為現在CPU 平技術高性能好,雙CPU底板會貴D,Display 咭用Nvidia可以改咭,有可以平D,Ram用133mhz有經濟,到自已成熟有經費容許啦先買部貴D,舊機要來render用這樣最化算。
ChildPark
文章: 316
註冊時間: 2日 6月 2002年, 12:03
文章Cyber Oxygen » 4日 6月 2002年, 00:40
其實改左之後同原本的貴咭系爭d...
改咭要視乎 原本個將geforce 系邊間廠出
不同的廠會用不同的零件( eg. ram的speed ) ..
改出來效果會唔同..
還有其他因素....
如果你想穩定d...
始終用貴咭會穩定過改咭...
文章HapZungLam » 4日 6月 2002年, 07:40
My college is using Xeon Dual 1.7 gig. 512mb ram, nvidia quotro 2 video card. it is super fast (compare with my home computer, just a stupid P2 350, 192mb ram, Nvidia TNT2 videocard)
The faster the better.
文章HapZungLam » 4日 6月 2002年, 07:43
i suggest you buy a Geforce 2 Ti and mod it with software to Quotro2. for the video card. This is the way to spend the least and get the best.
正在瀏覽這個版面的使用者:沒有註冊會員 和 8 位訪客
