maya建模的問題~
maya建模的問題~
文章cityheart1980 » 15日 10月 2003年, 00:54
NURBS與POLYGONS差別在那??
cityheart1980
註冊時間: 14日 10月 2003年, 03:08
文章Itoshin » 15日 10月 2003年, 02:06
單就視覺上來看.....NURBS是曲面構成,Polygon是多邊形構成....
Itoshin
文章: 9
註冊時間: 24日 9月 2003年, 13:59
文章johngalliano » 15日 10月 2003年, 12:04
NURBS(Non-uniform rational B-spline)
-a parametric (has uv) four-corner patch (quadrilateral),
-u tangent and v tangent are well defined,
-uv parametization can be uniform or non-uniform(refer to the doc),
-can be rational or non-rational (non-rational surface has its CVs weights all equal),
-can be of different degree or order (e.g cubic(degree 3, order 4), linear(degree1, order 2))
-has knot values, for reparametization, mimic spline of other basis (e.g bezier), multiplicity. (Refer to Renderman Companion pg 104-105, and Advanced Renderman pg 105-106 for details)
-can trim a nurbs surface (but better not to do it)
-need tesselation b4 rendering in maya.
Polygon
-no clear parametization
-uv (so called in maya) has to be projected onto the polygons
-can have as many sides as u want (but 4-side is usually good)
-can safely make holes on a polygon model
-need to be subdivided or smoothed b4 rendering
johngalliano
文章: 408
註冊時間: 10日 1月 2003年, 01:12
