想學MEL 應去那裡學?
想學MEL 應去那裡學?
文章keithwmg » 4日 3月 2004年, 00:54
我想學MEL , 但又對Computer Programming 完全不懂,
各位可否幫我諗一諗邊間學校會好D
我search 了幾間大學的進修課程,
大多數都系讀information technology,
好似對programming/MEL 幫助不大,
請大家被些意見給我好嗎? :o
THX~~~~~~~~~~~
keithwmg
文章: 99
註冊時間: 24日 5月 2002年, 15:21
文章cgworker » 4日 3月 2004年, 02:09
以前城大有得讀..... 不過近年唔覺有喇..
睇 Maya 個'help'自學喇...努力
cgworker
文章: 120
註冊時間: 31日 10月 2002年, 13:11
文章HammerChugoh » 4日 3月 2004年, 05:49
personal idea.
Mel are not difficult, actually quite easy. But you need to understand how maya work.
I think the best way to learn is to open the script editor then work as usual, finally study which command maya generated and which flat was turned on.
For example. when you create a nurbs sphere in maya, if you take a look at the mel it generates. there are more than one obj, which are the transform node and the shape node, were created. By studying something like this. you might know a bit more about how maya manage the scene and how can you use them as information when you script your tools.
HammerChugoh
文章: 272
註冊時間: 27日 7月 2002年, 06:50
來自: La La land
文章leeho » 4日 3月 2004年, 21:29
:o :o 學 mel 要懂得 c++ 8) 8)
文章keithwmg » 5日 3月 2004年, 02:00
leeho 寫::o :o 學 mel 要懂得 c++ 8) 8)
對呀,
所以我知道如果我不懂programming/C++ 的話, 要學MEL 就會很懂上手,
所以我想去學一些基本的programming ,
不知大家意見如何??
keithwmg
文章: 99
文章HammerChugoh » 5日 3月 2004年, 03:50
no, you don't really need C or C++ bkgd before you can really use mel. May be I should say this way, grab a C programming book, read the first few chapters which usually covered simple syntax like data type, variables and work flow(loops). Those material are enough for mel. Although I do encourage people to learn C or java, you just don't need them for mel.
HammerChugoh
文章: 272
來自: La La land
文章tylau » 5日 3月 2004年, 20:22
識JAVA...(找API技術)
便懂MEL...
睇SAMPLE PROGRAM, 很易上手(有JAVA底的)
tylau
文章: 105
註冊時間: 13日 8月 2003年, 18:39
文章3dfactory » 24日 4月 2004年, 11:45
3dfactory
文章: 44
註冊時間: 17日 1月 2004年, 23:48
