[討論]Maya+After Effects
文章yanronald » 10日 3月 2004年, 10:34
I have planned to use maya to build up my model and animation, and I use mental ray to render the realistic part(building for example), however, does mental ray support fluid effect in maya 5?
On the other hand, i know that using after effects can do layering and looks like a 3D scene, but what kind of files should I render in maya so that I can import it into AE?
Thanks
yanronald
文章: 19
註冊時間: 10日 3月 2004年, 10:28
文章tylau » 10日 3月 2004年, 18:24
差唔多全部FORMAT都可以IMPORT入去...
我就用開PIC/TGA SEQ.
tylau
文章: 105
註冊時間: 13日 8月 2003年, 18:39
文章yanronald » 10日 3月 2004年, 19:44
But i have a problem that the rla file rendered by mental ray do not contain the z depth information. In addition, it has made one more file about the depth information in the format of .iff , so how do i use it to make a 3D look in AE?
Thanks
yanronald
文章: 19
文章h2o » 10日 3月 2004年, 23:58
"3d look" ..... 唔系好明? depth 只可以做景深, out focus & fog 呢d 效果.
文章yanronald » 11日 3月 2004年, 14:14
3D look means have layer effect when the camera is dolly in
yanronald
文章: 19
文章winfred01 » 15日 3月 2004年, 21:56
in AE, u can mainpulate the position of layer by your self...and you don't really need Z-depth.... for layer effect
winfred01
文章: 14
註冊時間: 30日 1月 2004年, 22:15
文章johngalliano » 21日 3月 2004年, 14:24
for z-depth thing, u can render iff images, it has z-depth channel, u can copy the z-channel to the alpha channel and do the blur with some sort of mask blur. It is easy to do in Shake though i forgot the operation quite a bit. Maybe AE also have some sort of pluggin to do it
One thing is,..u need to know the depth near and far info, u can check it with fcheck. But for a sequence with depth varies a lot, then i dunno how to get the depth info easily,...maybe u need someone to write a little program for u to automate the task. Ah,..i think that will be a good chance to practice programming.
johngalliano
文章: 408
註冊時間: 10日 1月 2003年, 01:12
文章raf » 21日 3月 2004年, 15:58
i render iff as depth map but how can i input them as depth channel in AE?
raf
文章: 173
註冊時間: 28日 2月 2003年, 18:43
文章johngalliano » 21日 3月 2004年, 17:37
Use Shake or other compositing software. Maybe there is pluggin for AE to read z-channel,..i am not sure.
johngalliano
文章: 408
正在瀏覽這個版面的使用者:Bing [Bot] 和 9 位訪客
