mindthink virtual mirror becomes free tool
版主: HapZungLam
文章rryria » 8日 7月 2004年, 16:30
http://www.mindthink.de/ohm/virtualmirror
maybe u guys know already
symmetry modelling like the way lightwave can do
rryria
文章: 504
註冊時間: 1日 10月 2001年, 08:00
文章HapZungLam » 8日 7月 2004年, 23:49
why don't you just symmetry it or clone a negative version?
文章rryria » 9日 7月 2004年, 00:17
i have tried using symmetry map
and negative clone
but i discovered that when u add geometry to the mesh
they cant work anymore
also Right and Left side cannot merge together without seam in instant subdivison
but now this virtual mirror tool can do everything well
it's even better than the one lightwave have
because the symmetry plane can be defined by facet
that not constrain to YZ plane... etc.
rryria
文章: 504
文章HapZungLam » 9日 7月 2004年, 23:55
Symmetry map is totally useless unless you want to mirror weights. But, are you sure it doesn't work with negative clone?
you right click on your model and hit clone, scale your model in -1x.
you may merge them with your original to see it with no seam, or you may go modify -> poly mesh -> symetrize polygons. Symetrize polygons is working the same as the addon you've shown.
文章rryria » 10日 7月 2004年, 01:32
yes
xsi itself can do it
but that addon can let u interactively add geometry to the mesh in real time
very powerful
rryria
文章: 504
回到 Autodesk Softimage
