Use CV Curve....
Use CV Curve....
文章Maya初仔 » 20日 5月 2002年, 02:07
If i use CV Curve to revolve it be be an orange! Afterward,i would like to select thier front Vertex!! But i don't want to select thier backside vertex at the same time !!! Are there any setting as polygons Backface culling??? Cos, every time i select front side vertex, i will also select backside one!!! :oops:
Many ths for helping!!
Maya初仔
文章: 433
註冊時間: 3日 4月 2002年, 08:00
文章3DMan » 20日 5月 2002年, 02:38
我都唔知依家NURBS有冇得咁做, 不過以前我會將Camera的"FarClipPlane"調至較細數值 (例如少於4以下), 好讓距離Camera較遠的面不能display出來, 咁就唔會selcect到後面o既點。
3DMan
文章: 150
註冊時間: 7日 9月 2001年, 08:00
來自: HongKong
文章stantang » 20日 5月 2002年, 05:01
Yes, the FarClipPlane function is still working. Or if you just want to work on the front part, you can select all the front vertex in the top panel, go to the panel you want to work on then go to the penal menubar --> Show --> Isloate view--> view selected. This method only works with Maya 3.5 or above.
文章Maya初仔 » 21日 5月 2002年, 16:27
MANY THS! I WILL TRY IT !!! :oops:
Maya初仔
文章: 433
Maya初仔
文章: 433
