有個第三方render engine加入
版主: ed209
文章moc » 15日 1月 2005年, 23:49
呢個喎...
http://www.kraytracing.com/index.php?subpage=4&info=1
觀其發布訊息...
話速度奇高咁話...以四十幾倍計喎....
不過又好似有點通病...
由於是外置 engine...故雖然可以直接閱讀.lws及.lwo..
但又有唔少限制....最起碼....會有唔少shader插件無效....
但佢render質素又好似唔錯....幾靚咁...
大家睇睇
http://www.winosi.onlinehome.de/Gallery_t14_08.htm
Kray interface for LightWave
Kray is not just a plug-in. It is a complete rendering system that can render even if you don't have LightWave installed on your computer. Kray reads LightWave scene/object files directly. That means not all of the original LightWave features will work. You also can't expect that all LightWave's plug-ins will work with Kray, especially plug-ins LW uses at rendering time. However, such solution has many advantages as well. Kray is not limited to LW architecture and provides you powerful features not to be found in LW.
Plug-in for LightWave is only an interface between Kray and LW. It allows you to set all Kray's specific rendering parameters from LW and just click to start rendering. It works with LightWave 7.5 or above.
Supported LightWave features:
Geometry:
polygons
Textures:
multi-layer textures
image maps
blending modes: normal, additive, subtractive, difference, multiply, divide, alpha
Lights:
ambient, distant, point, spot, linear, area
Animation:
hierarchy
bones, weight maps
More details can be found in Kray's user manual.
[url][/url]
moc
文章: 735
註冊時間: 21日 8月 2001年, 08:00
文章badBoy » 16日 1月 2005年, 02:58
thz!推一下. :mrgreen:
badBoy
文章: 142
註冊時間: 13日 8月 2001年, 08:00
回到 NewTek LightWave 3D
