商標設計
商標設計
文章LAMZA » 21日 7月 2005年, 20:47
各位朋友!本人有樣野想請教一下!
唔知各位有冇一D關於商標設計的網站?
& 可唔可以講講設計一個商標的流程是點?用咩工具?要有咩注意的地方?等等……
Thx Q~~~~~~~~~~~~
***主題與CG關系不大,如果犯了板規,不要殺我>O<
LAMZA
文章: 596
註冊時間: 9日 4月 2004年, 21:33
文章stantang » 22日 7月 2005年, 04:40
Here is my workflow:
1. Draw your ideas down, then finalize the look, you combine the elements from different ideas
2. Scan the final drawing, use illustrator to draw the logo so that you have a digital version of it
If it's 2d, you would add color/detail/texture in illustrator, then you're done
If it's 3d, import the AI file into a 3d program, then model the logo using the lines from the AI file. Add shading/texture/lighting etc..., then render the final image.
文章LAMZA » 22日 7月 2005年, 15:59
Thx Q~~~你的回覆!
但想多問少少,因為我未有實戰的經驗!
想問下Logo是唔是要畫咩咩網格?然後再標示出Logo的顏色(CMYK)?
*沈日特登走去銅鑼灣睇Design的書,可惜搵唔到設計Logo的書籍,但睇到好多人地設計的Logo,真是好正^o^
LAMZA
文章: 596
文章stantang » 22日 7月 2005年, 21:48
Lamza, just like any other design, you need to have a strong idea/concept to create a good logo... I don't think there's any books on teaching how to design a logo. You will have to "see more, do more, learn more". we can only help you with the 實戰 part. :)
"想問下Logo是唔是要畫咩咩網格?然後再標示出Logo的顏色(CMYK)?"
網格 is more for hand drawn logo, I don't think anyone is using it anymore for logo design. Do you know Illustrator/CoralDraw? You can outline and apply the color to your logo in Illustrator/CoralDraw. CMYK color can be assign there as well. You don't need CMYK color if your logo is not for printing.
文章LAMZA » 22日 7月 2005年, 22:04
哈哈!真是非常多謝你的回覆!我很喜歡設計,不過設計的范圍真是好大!
其實我覺得鍾意設計的人,應該都唔會規范自己系途個媒介上,CG、Graphic、建築、好多好多野都是有關聯,好似大自然一樣^o^
我應該會用Illustrator做!開始要動工lo ^o^
再一次多謝你 圖檔圖檔圖檔
LAMZA
文章: 596
文章stantang » 22日 7月 2005年, 23:06
you're welcome! When I think of design, I think of something that can change the world. It does and it did! :)
文章LAMZA » 26日 7月 2005年, 00:08
我剛做完一個LOGO,想知道我做得正唔正確!
想各位比D意見。我用o左3種唔同的字體,想知道邊一只或其他字體會更合適?另外字距、行距&圖案的距離有冇問題?
LOGO意思:
個LOGO是關於插畫,圖案分別有c、o、i的英文字母!(o字母有少少講唔通吧?)c、o、i同時形成一支畫筆&圖案最低有一條紅色筆觸線,是由畫筆所畫出來的。圖案整體的意思是想表達出用畫筆去繪畫!
另外附上2張logo的layout,入面邊D是ok?
LAMZA
文章: 596
文章h2o » 26日 7月 2005年, 02:24
1, 2, 5, 6 organization 個名好似細得滯, 唔系咁 balance
5 既 fonts 太幼, 6 又太粗, 2 有紅色字頭就搶眼d, 不過要小心紅色會比黑色睇落幼d (相同 size 計), 你要 set 大佢 or 肥小小.
另外佢地個簡稱系"IOC" 定系"IC"?? 因為有d 公司社團個簡稱會 ignore 左preposition, "the"... ... 又有d 會用頭兩三個字母砌出黎.
我覺得3 & 4 都唔錯既, 不過我想問下有問試過d hand writting fonts? :wink:
正在瀏覽這個版面的使用者:沒有註冊會員 和 7 位訪客
