我是新手,第一次同大家見面! 可否教我少少野?
文章SuperDuper » 7日 7月 2002年, 21:50
hello~~~~!
我想請問一下,我畫左一幅畫,然後 scan 左入部腦~~
但線條太粗糙,想在電腦裡面修改。
請問是用什麼程式同埋可唔可以教我一些修改的方法?
謝謝~~~! ^^
SuperDuper
文章: 12
註冊時間: 7日 7月 2002年, 21:44
文章Bigeye » 7日 7月 2002年, 23:45
You could use photoshop to change the brightness/contract for slim the line. If you feel that the line still rough, you may pass the photo to illustrator or freehand to redo the outline. That will be more perfect. On the other way, it will take a lot of time.
Bigeye
文章: 50
註冊時間: 27日 2月 2002年, 08:00
來自: HongKong
文章SuperDuper » 8日 7月 2002年, 07:36
我就系唔明點樣 "redo the outline"~~~!!
要在電腦重新畫過 d line????
SuperDuper
文章: 12
文章Bigeye » 8日 7月 2002年, 09:20
Depended on how perfect you wish to have. If you need a clear clean line, I suppose you need to draw it again. By the way, could you tell me what the purpose you want? I could help you what the method is the best choice !
Bigeye
文章: 50
來自: HongKong
文章HapZungLam » 8日 7月 2002年, 13:30
Post your scan. so that we can fully understand what is your goal.
文章SuperDuper » 8日 7月 2002年, 13:55
我畫左只 pocketmon,想在電腦上色,做到好似卡通片咁!
喔~~~~!!
點樣 post 出來? :o
SuperDuper
文章: 12
文章Bigeye » 8日 7月 2002年, 17:53
By case ! If I animate the 2D pocketmon, the best way I will choose the illustrator to have a perfect line. It is because we can change some point to have different outlook. Then, we will be more easier to create in Flash. If I need the still 2D cartoon pocketmon, the purpose just want to fill some colors. I prefer to adjust "brightness and contrast" in photoshop for slimming the line. You could paint it in photoshop, painter... and so on. Try !
Bigeye
文章: 50
來自: HongKong
文章SuperDuper » 8日 7月 2002年, 18:22
Where is "brightness and contrast"???
SuperDuper
文章: 12
文章Bigeye » 8日 7月 2002年, 19:35
[ Photoshop 6.0 ]
In menu bar, find "image", then "adjust" , so you could find "Brightness/ contrast". No hot key !
Bigeye
文章: 50
來自: HongKong
文章SuperDuper » 8日 7月 2002年, 19:52
Thank you very much~~!! :D
SuperDuper
文章: 12
