does SLI support 4 x mons?
一切有關顯示卡的消息及討論
版主: Cyber Oxygen
文章acog » 28日 3月 2006年, 13:01
yes, i mean i want use 4 monitor with one system.
i'm using 7800GT, if SLI can support 3 or 4 monitor with sperate work area, i will plan to use nf4 SLI 8)
acog
文章: 19
註冊時間: 6日 1月 2006年, 13:52
文章stantang » 28日 3月 2006年, 14:14
You will need two of those cards and turn off SLI multi-GPU mode in order to use 4 monitors... If multi-GPU mode on, all cards will work as one, so only one monitor is supported.
文章acog » 29日 3月 2006年, 12:18
stantang 寫:You will need two of those cards and turn off SLI multi-GPU mode in order to use 4 monitors... If multi-GPU mode on, all cards will work as one, so only one monitor is supported.
thats mean it is not running on SLI mode, just plug with 2 display card only... if do, can i use different model? e.g. 7800 GT and 7800GTX/ 7900 ?
acog
文章: 19
文章stantang » 29日 3月 2006年, 18:22
acog 寫:
you should be able to, but you still want to turn on SLI someday, correct? I heard SLI works better with two identical cards.
回到 Graphic Card News & Talk
