由 darkElf » 5日 7月 2006年, 19:04
There is one tip. May be is helpful to you.
If your scene is high polygon or complex, the exported swf file size could be quite big and it might not playback smoothly. Then, you could try to render it as a image sequence with 12 fr/sec. Import it to flash directly. The compression file size will be smaller than the exported swf and playback smoothly.
