想請教caustic 的問題
想請教caustic 的問題
文章deshk » 1日 9月 2007年, 11:56
I follow a tutorial, and try to recreate a wine bottle and a glass of wine.
I turn on both "emit photons" from the key light, and "caustic" and "raytracing" from mental ray render. But somehow it doesn't look like it has created any caustic. Btw, the rendering time with caustic turned on is just same as the rendering time without caustic.
I did double check the setting from the tutorial, I don't know what went wrong.
Can anyone explain roughly how it works please? And what I need to pay attention, when I try to use caustic? thanks
The mental setting, and the key light setting.
My render with caustic turned on, but it doesn't look like it is.
This is the final render from the tutorial. It provide a final scene file. I render it out on the same computer.
deshk
文章: 46
註冊時間: 13日 12月 2006年, 19:31
文章stantang » 1日 9月 2007年, 12:06
Are you using raytrace shadow for your lights?
文章deshk » 1日 9月 2007年, 12:10
yes I'm using raytracing.
- Use Ray Trace Shadows is on
- Light Radius: 0
- Shadow Rays: 1
- Ray Depth Limit: 1
deshk
文章: 46
文章stantang » 1日 9月 2007年, 12:28
deshk 寫:yes I'm using raytracing.
- Light Radius: 0
- Shadow Rays: 1
You probably want to raise the Ray Depth Limit as the shadow can't pass through your glass and wine with just 1 for that setting.
文章deshk » 1日 9月 2007年, 12:39
I have just run a test, I increase the Ray Depth Limit to 10.
It makes no changes on the render.
And I check the final scene of the tutorial, it's interesting that the Ray Depth Limit is 1 only.
I think Caustic doesn't like me : p
deshk
文章: 46
文章stantang » 1日 9月 2007年, 13:02
deshk 寫:I have just run a test, I increase the Ray Depth Limit to 10.
May be you want to increase the Max Photon Depth as well.
文章deshk » 1日 9月 2007年, 22:51
thanks, I will try : )
deshk
文章: 46
