Problem: Crash when use "Parametric Deformers"
文章Kraretto » 2日 9月 2007年, 14:52
Anyone has seen this problem please?
When I use any deformers, it will kick me out and close the 3ds max immediately without any error message. It happens when I use the right panel or use the pull down menu from menu bar. Also, it crashes even if I create a new simiple object. I tried to remove the 3ds max & its regedit, and re-installed it. But it does the same crash. Also, I updated the latest video driver and installed the 3ds max SP1 & SP2. Although it only affects the deformers, it doesn't hurt me too much. However, it is really annoying when I really wish to use it. I wish I can fix it without re-install my windows...
Remark: I am sure I could use the deformer before but it just crashed.
Kraretto
文章: 19
註冊時間: 1日 1月 2007年, 12:15
文章sobig » 3日 9月 2007年, 06:35
it is a common problem for max if u get file crash.
the only way you can do is to save a couple of times before your file crash.
文章Kraretto » 3日 9月 2007年, 14:57
Thanks for your reply.
You mean my data file crashed? However, even if I open a new file and create a new simple object (eg. a box) and change it into Poly. It will kick me out to window when I try to apply any deformers. Any comments please?
Kraretto
文章: 19
文章sobig » 3日 9月 2007年, 17:04
are you using max8 or max9?
文章Kraretto » 3日 9月 2007年, 20:06
Some detail of the configuration here:
3DS Max 9 + SP1 & 2
Window XP + SP2
Video: FX5900 Used v93.71 before and updated to 162.18, both show same problem
Tried DirectX 9.0c and OpenGL, both show same problem
Kraretto
文章: 19
文章sobig » 4日 9月 2007年, 15:05
post your max file that includes a simple box.
then, i try to change it to Edit Poly.
let's see what happen.
if it works, that mean your video driver or window get problems
文章Kraretto » 4日 9月 2007年, 22:01
Thanks. Here is the file.
box.zip
(28.34 KiB) 被下載 532 次
Kraretto
文章: 19
文章sobig » 6日 9月 2007年, 00:00
mate, i can open your max file by max9,
i got no error msg when i convert the box to editable poly and apply any deformer.
i guess your pc and windows get problem actaully.
文章Kraretto » 6日 9月 2007年, 17:18
Many thanks.
...It means I need to re-install my window. TT.
Kraretto
文章: 19
文章sobig » 6日 9月 2007年, 23:27
no worries.
