3dsmax Video Tip VRay Material Dirt
文章tensun » 28日 2月 2008年, 09:20
I find a new Vray shader recently, the “vraydirt”(it also known as a AO shader in Vray) shader. And I make a render test with share some tips here, hope it helps.
Video Preview (youtube)
Full Version Download (tensun3d.com)
This is the result before applying “vraydirt” shader, it looks shadow-less and weight-less.
This is the result after applying “vraydirt” shader, it looks more real form previous one and rendering very fast. It looks like a little “3S” effects, but I’m still hard to make a good 3S control from Vray.
The final results, I applying reflective materials and adjusting glossiness values. The rendering speed is slowing down however with a very well result, we can try more values between the speed and quality.
tensun
文章: 16
註冊時間: 6日 9月 2007年, 15:35
文章sobig » 28日 2月 2008年, 21:54
that's cool.
will u share the shader with us?
文章h2o » 28日 2月 2008年, 22:12
文章tensun » 28日 2月 2008年, 23:14
ya, it's the internal texture.
tensun
文章: 16
文章sobig » 2日 3月 2008年, 17:41
yes, it is like final render - Final Shader stuff.
