What's the different between displacement map, bump map?
文章limitvision » 28日 6月 2008年, 19:43
不太了解什麼時候用那一種貼圖, 希望有人解答啦, 謝謝
limitvision
文章: 44
註冊時間: 16日 12月 2005年, 20:15
文章stantang » 28日 6月 2008年, 21:06
Bump map is simply a 2d effects, it doesn't really bump the surface, good for things that aren't close to camera. It renders fast too. The problem is you won't see the bump when you look at the surface from the side.
Displacement map will move the actual CV/vertex of the surface when render, it's like you model the detail on the surface. It requires a high density surface for the map to work. It's slower but good for surfaces that need to be close to camera or view from the side.
文章風之谷 » 29日 6月 2008年, 15:57
displacement MAP "bump" 出來的位置可以受到shadow,亦會cast 到shadow,
bump map 就唔可以啦。
(有錯請更正~)
風之谷
文章: 276
註冊時間: 25日 7月 2006年, 02:20
外號: 呀峰
