RENDER LAYER 問題哦~
RENDER LAYER 問題哦~
文章cassius_lauu » 1日 4月 2009年, 20:20
我modelling 果陣中途render 下睇睇效果~咁就開左個occ 同 color ge render layer..
點知再mdoelling果陣.....o系color layer 做左野......master layer 無左一堆model.....
想問問~有無方法可以將o系color layer ge model copy番/搬番去master ge render layer ar????
cassius_lauu
文章: 8
註冊時間: 20日 2月 2009年, 23:24
文章stantang » 1日 4月 2009年, 20:35
The objects are there, they are in all layers, render layer is like display layer, you can add objects to a certain layer so that layer will include them when render. Normally, masterLayer should should display all the objects in your scene, if you don't see them, just go to your masterLayer, open Outliner and unhide them.
文章cassius_lauu » 1日 4月 2009年, 20:47
stantang 寫:The objects are there, they are in all layers, render layer is like display layer, you can add objects to a certain layer so that layer will include them when render. Normally, masterLayer should should display all the objects in your scene, if you don't see them, just go to your masterLayer, open Outliner and unhide them.
OH no~~it doesn't work.....when i click to master layer....the outline or hypergrahp are also display all of the model.....they havn't hide....
and i found that.....in the option of render layer...it has tick add new objects to current layer.......
is that mean......add the new objects to the layer i currently selecting??????!!
and when i move to master layer, some object's material has been changed to use the defult material~~>.<
wt should i do~then~
cassius_lauu
文章: 8
文章cassius_lauu » 1日 4月 2009年, 21:20
too bad that i have made a solution.....in an urgent time~~
for the model.....i combine all of them....then all of of them changed to master layer....made all the material and texture have to be assign again, luckly the UV MAPPING hasn't change, so i just need to assign only....
but the lighting has to be set again~~~>.<~
cassius_lauu
文章: 8
文章stantang » 1日 4月 2009年, 21:28
How long have you learn Maya? I have to ask that, cause an object being hidden will still show up in Outliner but display in dark blue color... just select those objects and hit Shift+h
What version of Maya are you using? I think something is wrong with your Maya, cause even you had the "add the new objects to the layer" turn on, the new objects should show up in masterLayer no matter what (unless they are hidden).
For your second question, there is no easy way to assign the materials back to the masterLayer unless you want you do it one by one. But the question is, why do you want to do that, there is nothing special with masterLayer, you can create your own masterLayer by adding all objects to one layer and completely ignore the default masterLayer.
文章stantang » 1日 4月 2009年, 21:33
cassius_lauu 寫:but the lighting has to be set again~~~>.<~
You don't need to reset the lighting....
As I said just make another regular render layer and add+unhide the objects/lights you need
文章cassius_lauu » 1日 4月 2009年, 21:36
-----------------------deleted by user
最後由 cassius_lauu 於 24日 11月 2011年, 03:48 編輯,總共編輯了 1 次。
cassius_lauu
文章: 8
文章PetorialC » 1日 4月 2009年, 21:38
[Off topic]
There has been a problem (maybe a bug) with the layers of Maya. (I am talking about the normal display layers that I am more familiar with.) When I add an object to an layer turned to invisible, sometimes it can not be added. Sometimes an object can be in more than one layers. I am using Maya 2008 Ext 2. I don't know if this happens to the render layers too but I hope Autodesk will fix them soon.
[/Off topic]
PetorialC
文章: 164
註冊時間: 16日 2月 2008年, 11:57
文章stantang » 1日 4月 2009年, 21:53
老友,請問我邊度笑緊你呢?我想知你學咗幾耐系因為我想知你會唔系因為未學到而miss咗D野嗜... tutorial都有分難度啦...
我如果唔想答你就唔會咁快回你一大篇野啦,系咪?我打中文慢所以用英文回你系因為知你急,而家用中文回你系因為怕你亂諗。
文章liarliar » 2日 4月 2009年, 00:26
cassius_lauu 寫:
stantang 寫:How long have you learn Maya? I have to ask that, cause an object being hidden will still show up in Outliner but display in dark blue color... just select those objects and hit Shift+h
i think u have a problem that wasn't willing to help me
is that all the admin is the same as you??
(at least my method can solve my problem in an urgent time, no matter it is a stupid method or not)
Friend, Stantang is not that kind of person.
愛人難,我肯學,定能愛下去!
liarliar
文章: 71
註冊時間: 7日 10月 2002年, 17:06
來自: 烏托邦
文章h2o » 2日 4月 2009年, 01:53
開左 render layer 之後, 入左去其中既 layer 做野的話, 你又 hide & show models, 有時系會影響到 master layer key 左 visibility off
你都話自己系 beginner, 中間 step 做錯都唔奇, 好多時到左好後先發現問題, 要搵番個問題原因就要知你做過咩, 但可能性實在有太多, 來回問問答答幾次好正常. 而且我唔系好明你 redo lighting 既意思... 如果真系我想像個種, 你個 maya file 似 corrupt 左.
re: PetorialC
maya render layer 好多時做做下會傻左, layer 多又會傻, 分左 layer 之後import model 就更易傻.
文章jacky1987hk » 2日 4月 2009年, 02:05
stantang 寫:老友,請問我邊度笑緊你呢?我想知你學咗幾耐系因為我想知你會唔系因為未學到而miss咗D野嗜... tutorial都有分難度啦...
stantang C兄 is a good man ar~~~
teach me a lot~~~~
jacky1987hk
文章: 142
註冊時間: 3日 1月 2009年, 19:15
文章ZU » 2日 4月 2009年, 14:03
會員 cassius_lauu ,
先要讓你知道 , 這Cg-forum裡的 MOD 都系極具經驗及非常熱心的專業人士(雖然都有潛水MOD :oops: ) ,但這並不表示他們每每都是必須回答所有問題的。
我見閣下發問題竟連一句"唔該(ThX)" 都無... 現在人家幫你 , 你仲反串返轉頭, 態度明顯是出了點問題!! ((老實說 , stantang 兄已經非常客氣及有心幫你,更何況 stantang 兄的回答根本都無串(笑) 你之意))
作為這裡的Host 及stantang 的朋友 我必須在此站出來支持他的 ,
希望大家專重一下我們的MOD 及其他會員 , 專重一下自己 !!
問問題時先做一下Research , 問人時加一句"唔該" ( 好難嗎?)
這裡不是膠人討論區, be professional..., 基本禮貌不用教吧!!!
ZU
創辦人
創辦人
文章: 733
註冊時間: 30日 7月 2001年, 08:00
外號: CG 窮人協會榮譽會長
文章Dxxk Mx » 2日 4月 2009年, 16:27
cassius_lauu 寫:i know it already, but the problem is there is nothing change for the displaying color lor, if it has been changed , i think i can solve my problem, and no need to ask anyone lor, it is not related to how long have i learn maya lor, is that if i am just a beginner, u will not teach me?
人卜街, 人地答緊你問題, 反而你發悔氣.
cassius_lauu 寫:or u just give me a smile and say try more and learn more then finish this topic??
:lol: :lol: :lol: 之前咁多個 post 都未出過 smile, 你思覺失調呀, 依家系你自己 finish 個 topic 咋!
cassius_lauu 寫:Or if i am not a beginner, then u will just ingore my question?
依家好多人睇你個 question, 你滿意啦!
cassius_lauu 寫:i think u have a problem that wasn't willing to help me
stan 打左咁多只字, 都叫 wasn't willing to help you? 俾我 fxxk you 添啦!
cassius_lauu 寫:is that all the admin is the same as you??
關乜春事
cassius_lauu 寫:at least my method can solve my problem in an urgent time, no matter it is a stupid method or not
問問題系你, 做錯野制造問題又系你, 唔想下次有同樣問題就要搵征結所在, 你鍾意咪繼續做錯哂野又唔知發生咩事咯, 你咁做野法第時一定比人小到"人卜"街
P.S. 你唔好比我知舊年 vtc 畢業那個就系你......
Dxxk Mx
文章: 121
註冊時間: 18日 2月 2004年, 00:30
來自: Somewhere but not here
文章cheungcheung » 2日 4月 2009年, 17:44
嘩...乜依家d beginner 問問題咁凶狠, 當呢到d 版友,版主系學校d阿sir呀? stantang答你野冇收你錢架,老逢咩依家。
雖然我都系beginner, 但我問問題都識appreciate答我既人架。
cheungcheung
文章: 104
註冊時間: 8日 7月 2002年, 16:26
正在瀏覽這個版面的使用者:沒有註冊會員 和 22 位訪客
