[問題]question about converting!!
各位可在此處交流及討論任何軟件,
文章Barry Yue » 12日 1月 2003年, 00:37
Dear All, i'm new in poser 5, i just wonder is there any converter out there for convert the output to different format, such as maya or 3dsmax. Or it can't be converted. thx for help :D
Barry Yue
文章: 7
註冊時間: 12日 1月 2003年, 00:08
文章CraZ3D » 12日 1月 2003年, 02:34
Poser 5 的 File Formats :
Import
AVI, PCT, PNG, BMP, JPG, WAV, BVH motion, LightWave 5, OBJ, 3DS, DXF, 3DMF
Export
AVI, Flash-SWF, PCT, PNG, BMP, JPG, BVH motion, Viewpoint Experienced Technology (VET), OBJ, LightWave 5, 3DS, DXF, 3DMF, RIB
CraZ3D
文章: 1068
註冊時間: 12日 8月 2001年, 08:00
來自: Hong KONG
外號: 富X代
文章Barry Yue » 12日 1月 2003年, 17:05
thx a lot :D
Barry Yue
文章: 7
文章supercat7xx » 15日 1月 2003年, 13:35
請問你的poser 5 運行速度如何?快不快?
supercat7xx
文章: 282
註冊時間: 12日 11月 2002年, 12:30
文章Barry Yue » 15日 1月 2003年, 19:00
not really fast, usually it takes few seconds to reflash the screen from window to window and the worst is always hang! :cry:
howz yours?
Barry Yue
文章: 7
文章supercat7xx » 15日 1月 2003年, 23:29
它比 poser 4 及 pro 還要慢很多,雖然 5 有很多很好用的新東西,做出來的人物又很真,不過我現在還是用回poser 4. :cry:
supercat7xx
文章: 282
文章Barry Yue » 16日 1月 2003年, 01:37
Actually, i use poser for modelling only, cox i feel hard in modelling (and of cox i'm lazy to partice), i always look for a software which can make model easily and thatz y i chosen poser. But, there has a lot of problems remain, cox poser is not a real plugs-in progamme for any 3D sofeware, such as maya ......etc. So the output is not fully competable with them and this just make me mad again, but is much better now. what i mean much better is, now a day, i don't have to build everything myself, i can use up all the models in poser and just simply export it to maya then modifily them a bit, thatz it, much quicker and easier than before.
how about u, y chosen poser for animation making? there has so many progammes out there in the market, y chose poser?
Barry Yue
文章: 7
文章supercat7xx » 16日 1月 2003年, 22:34
sorry! 由於小弟小時賴讀書,看不明各下的英文! 所以都不知點回應?!
我本來是玩3D的,不過現在反而玩2D,現在我通常用poser 及photoshop,
painter一起用,所做出來的作品全都是平面的.
supercat7xx
文章: 282
文章Barry Yue » 17日 1月 2003年, 02:44
sorry. Actually, i'm not really good in english(and there is so many typo, hope u don't mind) but, i'm just lazy to learn chinese typing, so.............. sorry about that.
From now on, i will try my best to type more chinese. Sorry again.
here is the translation:
實際上, 我使用poser 只為modelling, 我感覺艱苦在modelling上(實際上,我是懶惰對practice), 我總尋找可能容易地做模型 thatz y i 選上poser。但, 許多問題依然是, poser 不是一真正插座在 3D sofeware progamme, 譬如maya...... 等。此產品不是充分地compacted(協定) 與他們, 這再使我瘋狂, 但是, 現在, 我不必須修造一切, 我可在poser 用盡所有模型和在maya modifily, 比以前較快和比較容易, you 怎麼樣選上poser, 為做動畫? 那裡有許多progammes 在這個市場, why選擇了poser?
Barry Yue
文章: 7
文章supercat7xx » 17日 1月 2003年, 13:48
我的情況和你差不多,我造MODELING是用"Rhino"造,不過做出來的效果和想像中有很大的差別,當然這是使用上的方法問題,但當做到一個算是滿意的時候就發覺很費時.所以就常試用"poser",poser在某程度來說時很好用的,不過就限制很多,主要就是難以素造亞洲人面孔,在3D MAX 使用時想修改某部分手,腳,面容都是一個難處,但如果用來做插圖及插畫的話就真是不錯,我現在就在這方面常試,你又有何健意? :)
supercat7xx
文章: 282
文章liu_0083 » 17日 1月 2003年, 16:17
I think the software such as poser and bryce are for beginners. But once you have experience, you will be bored with them and turn to maya or lightwave. :D
Do what you are to do, go where you are to go.
liu_0083
文章: 33
註冊時間: 15日 7月 2002年, 21:16
來自: hk
文章Barry Yue » 22日 1月 2003年, 00:05
yeah, ture. 真的很難去修改details,所以我仍然努力去做model in maya. 我本身對建模都不大有興趣,but, 我喜歡animation, so i have to learn how to build model, meanwhile, i'm looking for some plugs-in for easy modelling in maya, but, 我沒有法子找到,所以仍在努力中.
至於,各porgammes有不同的優點,所以很難defined那一個是for beginner or adv. i just think 簡單是best (simply is the best) cox, i don't have to learn all the theories and i don't have to understand what button for what, or i don't have to understand the relationship between them........... something just make me 發瘋! 其實, poser 也好, maya 也好, they are tools only, the most important element is us, if we are creative enough,那麼我們便可以chose what tool to use! 所以我個人認為先做好基本,then chose ur tool to express ur ideas.
Barry Yue
文章: 7
回到 其他軟件討論
