Unwrap UVW
Unwrap UVW
文章panit5 » 22日 4月 2017年, 17:21
Hi, all. I am new to this forum and have the following question:
Do anyone knows how to properly unwrap the bolt I attach?
Many thanks!
螢幕擷取畫面 (9).jpg (35.06 KiB) 被瀏覽 33677 次
panit5
文章: 12
註冊時間: 1日 4月 2017年, 01:48
Re: Unwrap UVW
文章sobig » 25日 4月 2017年, 13:58
In your case, you can select your original UV (your UV of individual model) with "Polygon Mode" in UV Editor.
By the way, you can have a look of this tutorial. It demonstrates the UV technique of "Point-to-point seams" and really useful in most of cases.
連結至影片網頁
hope this help.
Re: Unwrap UVW
文章panit5 » 3日 5月 2017年, 16:51
Thank you for your help!
The tutorial is wonderful. However, it still can't solve my problem.
I have tried used Box Mapping under Normal Mapping, Edit Seams and even Cylindrical Mapping methods, but the the problem persist on the sides on the bolt model. The UVs over there are still not very ideal.
Do your guys have other suggestion?
Numerous thanks!
panit5
文章: 12
Re: Unwrap UVW
文章sobig » 4日 5月 2017年, 14:06
Do you mind to share your max file here? I try to open it and play around with that.
Re: Unwrap UVW
文章panit5 » 4日 5月 2017年, 16:08
Sorry, I can't send any file with the file extension . max.
How can I send you the file?
A thousand thanks!
panit5
文章: 12
Re: Unwrap UVW
文章sobig » 8日 5月 2017年, 15:36
mate, you can just upload your max file right here.
Re: Unwrap UVW
文章panit5 » 12日 5月 2017年, 11:51
Sorry, I have tried many times , but it keeps saying file with .max extension cannot be uploaded!
panit5
文章: 12
Re: Unwrap UVW
文章ZU » 12日 5月 2017年, 11:55
panit5 , may be you send file to cgv.info@gmail.com , we will pass it to SoBig Sir
ZU
創辦人
創辦人
文章: 733
註冊時間: 30日 7月 2001年, 08:00
外號: CG 窮人協會榮譽會長
Re: Unwrap UVW
文章panit5 » 12日 5月 2017年, 16:57
O.k, thanks a lot!
panit5
文章: 12
Re: Unwrap UVW
文章panit5 » 21日 5月 2017年, 13:16
Thank you so much for the help all you guys have offered, especially John Siu!
May I ask John how could you fix my file?
A thousand thanks!
panit5
文章: 12
Re: Unwrap UVW
文章sobig » 22日 5月 2017年, 14:41
Hi Panit5, good to hear you have solved your problem. I can give you some screen caps later on. I get back to you asap.
Re: Unwrap UVW
文章panit5 » 24日 5月 2017年, 11:19
It dawned on me that you squared off the UVs by using the Freeform Tool in the Edit UV window.
Am I right?
I often wonder what are the number of seams should be left on a model? I have been modelling a chopper and after I flattened the UVs and stitched some of them together, I find that there are still some of them left and I am considering if they should be kept.
I have attended several job interviews for CG jobs, but some of them said that my portfolio was not rich enough! I may post the link of my portfolio on the forum in order to gather valuable opinions from you guys.
Thanks a lot!
panit5
文章: 12
Re: Unwrap UVW
文章sobig » 30日 5月 2017年, 17:29
Yes, I used Freeform Tool to edit the UV that I want. For the UV types, it depends on your observation and experience. The checker mapping can help you much to figure out the relationship between seams and UV edit.
Re: Unwrap UVW
文章sobig » 30日 5月 2017年, 17:37
For your case, here're the screen captures.
1. You can reset all the settings by "Convert to Editable Poly"
2. Assign UV Unwrap to model and use of "Point to point seams"
3. Make sure you edit your UV in vertex mode if you are using point to point seams.
4. Good use of "Pelt Map" under the Peel category. Normally, you can choose"Commit" in the simple UV"
5. Edit the UV scaling and proportion in Free form Mode.
6. We always assign a "Checker" map into the model in order to preview the UV scaling and connection among each single UV element. (two UV elements in your case).
Hope this help. Good Luck!!!
正在瀏覽這個版面的使用者:沒有註冊會員 和 7 位訪客
