[新聞]新CD有關HDRI
有關 Lighting 及 Rendering 技巧討論
版主: h2o
[新聞]新CD有關HDRI
文章Cyber Oxygen » 22日 2月 2003年, 00:04
Sachform Hdribase HDR Edition vol 1
The HDRIbase texture CD-ROM enables the user to do a very quick and realistic ligthing setup for 3D-scenes. No more trouble with hours of tweaking to get a realistic lighting, just open a HDRI/EXR and render it with your preferred application (the application must be able to support the .hdr-format). Most 3D-applications are able to deal with HDRIs natively or by assistance of a plug-in. The support for the OpenEXR format will follow soon.
The HDR images on the HDRIbase CD-ROM are able to do even more. Being real 360°/360° hemispherical panoramas without any disturbing elements (e.g. camera/photographer), the operator is able to use them as high-end source of reflection for his/her renderings. This means that you can turn your background freely and multi-directionally in order to receive the most suiting viewing angle for your scenes. No more distortions from the backside of a mirror ball, no camera or photographer inside the reflection of your architectural presentations.
http://www.sachform.de/products.asp
8)
文章HapZungLam » 22日 2月 2003年, 07:10
There has many tutorials and news about texturing from 3D total these days.
I really want to buy the 3 textures CD from 3Dtotal.com
文章Cyber Oxygen » 22日 2月 2003年, 15:50
which one ?
8)
文章h2o » 22日 2月 2003年, 21:06
我相信HDR-version已經夠用, us$99 有40張 hdr images, $20就有1張都幾抵 :lol:
自己整 hdr images 都幾煩, 仲要3000x1500..... 做 lighting 既cger 應該買架 :mrgreen:
文章Cyber Oxygen » 22日 2月 2003年, 23:14
HDR-version 是什麼來的?
文章h2o » 23日 2月 2003年, 00:26
.............. CO............你post出黎又唔睇裡面d資料............ 你比以前懶左好多wow :lol:
The HDRIbase texture CD-ROM is available in 3 different versions.
product 第一句已經講左有3個version :evil:
HDR-version: 40 lighting situations as HDR-format in 3000x1500 pixels (color/monochrome ->80 .hdr-images)
EXR-version: 40 lighting situations as OpenEXR-format in 3000x1500 pixels (color/monochrome ->80 .exr-images)
Bundle-version: 40 lighting situations as HDR-format AND as OpenEXR-format in 3000x1500 pixels (color/monochrome ->160 images)
p.s. OpenEXR 是由 ILM 開發的 high dynamic-range image file format
有一點較特別的是比 HDR-format 擁有更多 channels (R,G,B,A,Y,U,V,Z-depth/surface normal directions/motion vectors)
另外 file size 也較細, colour 也較細致
我認為OpenEXR 的用途在這數年間只可用於一流電影上, 不過我也正在開始研究 OpenEXR 可以有什麼software 可以配合及應用, 希望香港數年後可以用得著吧!!
最後由 h2o 於 23日 2月 2003年, 01:01 編輯,總共編輯了 1 次。
文章tdk » 23日 2月 2003年, 00:52
Digital Fusion already support Exr format for composite.
I think there will be more application to support this format as it have many potentials.
tdk
文章: 373
註冊時間: 16日 11月 2001年, 08:00
文章h2o » 23日 2月 2003年, 01:09
我研究的范圍較集中pre-production 的時期...... programming, shooting, lighting (現場真實 lighting, 不是後期 cg lighting)
因為從 ILM 裡所得資料有限, 未知後期制作還有什麼東西比 HDR-format 有更好玩的地方! :P
文章Cyber Oxygen » 23日 2月 2003年, 11:24
To h2o
我老了,看mon都看唔清了....
連EXR是什麼我都唔知了....... :cry:
8) :roll:
Lo Fan
文章Siegfried » 24日 2月 2003年, 11:58
Hopes that there will be Lo Fan, from Mainland or H.K. are both O.K.!
U.S.$99 :cry: ....too expensive for us (freelancers), but O.K. for company usage.
文章Cyber Oxygen » 24日 2月 2003年, 13:42
如果你真系有需要用到的話,
或者我都可以幫下你的.....
8)
文章workwire » 19日 3月 2003年, 17:26
This CD set are MUST have for all Cg users.
CD1 is Full color , the CD2 is MONO tone (black and white) of HDRI images
there are Dosch HDRI collections .... those are Great also :mrgreen:
workwire
文章: 36
註冊時間: 6日 9月 2002年, 12:53
Re: Lo Fan
文章heewing » 10日 11月 2003年, 15:36
Siegfried 寫:Hopes that there will be Lo Fan, from Mainland or H.K. are both O.K.!
me too...i dun want to spend too much for the disc, hope someone can provide where can buy the 'lo fan'..... :lol: :lol: :lol:
heewing
註冊時間: 7日 11月 2003年, 17:40
來自: hk
回到 ■ Lighting & Rendering
正在瀏覽這個版面的使用者:沒有註冊會員 和 8 位訪客
